Brake Pad + Rotor recommendation - Page 3 - Club Touareg Forums
post #21 of 35 Old 4 Weeks Ago
Originally Posted by VD-CH View Post
Sorry for the stupid question but bear in mind it's my first time replacing the brakes on a car...
What should I do to immobilize the car when replacing the brakes?
I don't want to discourage you from doing your own wrenching, but based on that question & statement, are you sure that you have all the necessary tools and knowledge to tackle this yourself? The task itself is not the most technical but it is super imperative that you do it correctly since it is what stops your vehicle...... Are you even mechanically inclined enough to figure out what needs to be disassembled and in what order to take the calipers\mounts\rotors off? Do you have service manuals that you'll be following?
I'm not really sure what you mean by immobilizing, but any time you lift any corner of a vehicle you need to ensure that it will not move..... being on flat, solid ground, choking the wheels, using jack stands, etc. are all basic and important safety factors.
You may want to educate yourself on this brake job task prior to just ripping things apart, or you may find yourself overwhelmed.
post #22 of 35 Old 4 Weeks Ago Thread Starter
Thanks for your concern TurboABA, much appreciated.
I've done a number of mechanicals repairs on the Touareg myself, just never done a brake job.
Flat solid surface, jack stands and wheel chocks are all things that I've already thought of and done. As far as I know, from all the Touareg Tutorials I've followed on YouTube, I have all the necessary tools.
Sorry for not being clear enough though in my previous post what I meant: is, for the rear rotors, having the car in P and the wheel in chocks enough from having it move, given that you still need to apply quite a bit of torque to loosen (and tighten) some of the bolts?
VD-CH is online now
post #23 of 35 Old 4 Weeks Ago
Typically you break loose your lugs prior to lifting the wheels off the ground...... once you have the vehicle on jack stands it's "SOLID" so you can apply torque until you go blue in the face......
I haven't messed around with the parking brake on these yet, but I believe there's some VCDS process involved in calibrating the system or setting the shoes properly......
post #24 of 35 Old 4 Weeks Ago
^^Early gen with mechanical parking brakes require no VCDS. If you have the mechanical parking brake lever, all is good.
Later Gens with the electronic parking brake (and push button switch) require the use use of VCDS to put the brakes in service position. Failure to do so risks needing a new replacement parking brake motor, which is roughly $500 per side.
post #25 of 35 Old 3 Weeks Ago
Well no question is stupid, one is always learning. So since one can not be too sure about working under such a heavy vehicle and you have only one life to enjoy the Teg, what I did was I put the wheel I had taken off under the car just as added safety. The rear brakes are the toughest to work on, there is not room enough to apply force appropriately. In my case, I already had an air compressor so I went out an bought a 300 ft-lb impact wrench, it took me fair number of blows to open the bolt, seemed like the previous mechanic must have "hung him self" when tightening the brake caliper.
If you buy the brake set from the shop in Massachusetts, he also sends you a new set of bolts so if you damage one while fighting with it you can always put in the new one. Also, make sure you have a torque wrench at hand.
My baby: 1969 300SEL 6.3
TouaregNut is offline
post #26 of 35 Old 3 Weeks Ago
Second Vehicle: 2015 V6 TDI
VD-CH -
Too bad you are in Switzerland. I have 3 Powerstop front brake kits I'm selling from Texas.
They are for the 04-2008 V10 TDI with 18Z Calipers
Power Stop Kit K4558 Front Z23 Evolution Brake Kit with Drilled/Slotted Rotors and Ceramic Brake Pads
I love them on my Treg. Anyone else interested in a great $150 deal on great front brake setup, contact me.
Mr_scsi is offline
post #27 of 35 Old 2 Weeks Ago Thread Starter
Due to availability and cost I'll need to order BOSCH rotors and BREMBO pads.
How come the front rotors are not identical??
About the pads...
BREMBO
Front: P 85 065 16mm x 190mm x 106mm
Rear: P 85 070 16mm x 112mm x 73mm
Sounds about right?
VD-CH is online now
post #28 of 35 Old 2 Weeks Ago
The discs/rotors are ventilated so they are handed left and right to ensure at as the car is travelling forward they suck in the cooling air through what is effectively a cast iron fan.
Make sure you fit the new discs on the correct side by looking at the old discs before you remove them!
The OEM equipment is Brembo discs and Pagid pads. Pagid makes the pads for Brembo as the latter has no friction material production capability.
post #29 of 35 Old 2 Weeks Ago Thread Starter
Would there be any reason why I shouldn't go for a combination of BOSCH rotors and BREMBO pads?
Should I just shell out the extra 50-100 bucks total to have 4x BREMBOs?
VD-CH is online now
post #30 of 35 Old 2 Weeks Ago
that's your call.
I'm not sure about Bosch rotors, who makes them, etc.
I'd personally spend the extra cash.
mpls is offline
Touareg brakes? Fonzi Brakes, Steering, Suspension, Wheels and Tires 74 06-13-2013 05:12 PM
brake pad fell off CsTDI General Maintenance & Repair 2 09-18-2009 09:29 AM
anyway to tell the cause of brake pad light? geremy Brakes, Steering, Suspension, Wheels and Tires 9 08-10-2009 06:00 PM
Brake Pad Recommendations? bahb7 Brakes, Steering, Suspension, Wheels and Tires 3 06-24-2009 02:58 PM
Brake Pad Numbers... gt40mkii Touareg Exterior Mods 2 08-22-2008 02:00 PM
