Bilsteinís for T2 Touareg - Club Touareg Forums
 4Likes
  • 1 Post By Steve_L
  • 1 Post By Steve_L
  • 1 Post By seafarer28
  • 1 Post By ridedirt311
post #1 of 8 Old 07-17-2018 Thread Starter
ridedirt311's Avatar
Touareg: 2008 V6
Soooooooo...any of you fine ladyís, and gents have any first hand experience with Bilstein B4, or B6 shocks & struts??? Or, do any of you know of any links on ClubTouareg to such info? Your help will be greatly appreciated.
Sent from my iPad using Tapatalk Pro
Mike H
ridedirt311 is offline
post #2 of 8 Old 07-17-2018
Moderator
Steve_L's Avatar
Hi Mike....have a read of this https://www.clubtouareg.com/forums/f...de-212530.html
ridedirt311 likes this.
Steve_L is offline
post #3 of 8 Old 07-18-2018 Thread Starter
Touareg: 2008 V6
Originally Posted by Steve_L View Post
Great read, Steve. Thank you so much for your help. I couldnít find anything anywhere. Tons of searching over the past few days, and nothing.
So, exactly which Bilsteinís did you use the B4s, or the B6s?
Mike H
post #4 of 8 Old 07-18-2018
Moderator
Steve_L's Avatar
They are B6 on front and rear
Steve_L is offline
post #5 of 8 Old 07-18-2018 Thread Starter
Touareg: 2008 V6
Awesome! I canít wait to get it done.
I noticed when I was eyeing up the OEM springs that there are several different options in terms of stiffness. Do the King springs come in the same flavors? Is there a stiffness, in particular, I should be getting for my base VR6?
I was thinking of doing coil spacers, as well. What are your thoughts?
Mike H
post #6 of 8 Old 07-18-2018
Moderator
Steve_L's Avatar
I can't recall the Spring specs...sorry. Will try and dig it up...or chat with the previous owner.
Thought about doing Alex's lift mod, but my mechanic said the that the parts provided, weren't going to work on mine. So, stayed with Bilstein/Kings upgrade.
I run a 31' (tip to toe) caravan, weight rating of 3100+kilograms and towball weight of around 280kg. The back end of the 'reg does drop slightly when hooked up, but front tyres remain firmly planted.
Steve_L is offline
post #7 of 8 Old 07-19-2018
seafarer28's Avatar
Originally Posted by ridedirt311 View Post
Awesome! I can’t wait to get it done.
Yes, you are right as there are a couple of different spring rates available and used by VW as OEM springs, they are identified by the combination of coloured dots painted on the actual spring themselves.
If you look at the pics I have attached from my 7L (200 3.0 TDI, the front coil is marked "MB" (yellow (possibly white) dots) and the rear is the "MH" (green + yellow dots).
I was told these coils are the "stiffest" OEM combination available and were possibly fitted because the vehicle was factory ordered with the tow pack, as there are other colour combinations available, why don't you have a look at your coils and see what colours you have?
The King Springs are not available in other versions however as they are marketed as "heavy duty" they noticeably do use a thicker rod material, length is the same.
If you want stiffer springs for occasional offroad work and you do not tow anything heavy my suggestion is that you source a set of MB/MH combination OEM springs as they will offer you the most comfortable ride especially if you plan to add spacers for a little additional height.
Don't forget with spacers you will loose some spring travel which will cause some additional ride "harshness" so sticking with OEM will minimise that effect.
Attached is a pic of the 40mm AG Fab. spacers I had originally fitted with the Bilstein/King Springs combination on my Touareg, if you haven't already read this here's the link:
https://www.clubtouareg.com/forums/f...di-166345.html
TonyB
Name:	Front OEM coil.jpg
ID:	216821   Click image for larger version
Name:	OEM Rear Coil.jpg
MY08 V6TDi, Campanella White
seafarer28 is online now
post #8 of 8 Old 07-19-2018 Thread Starter
Touareg: 2008 V6
Thank you, Steve. Thank you, Tony. I greatly appreciate the input. I think the B6s with the OEM MB/MH springs, and spacers are going to be the route I travel.
Steve_L likes this.
Mike H
