Air suspension leak help - Club Touareg Forums
post #1 of 4 Old 01-14-2018 Thread Starter
Touareg: 2010 V8
Send a message via Skype™ to piuric
Hi it is a 2011 V8 Touareg 7P0 front suspension with a small leak.
I can not insert the the youtube link here, but if you type on my youtube channel :
Right front suspension leak 2011 vw touareg
it will show the video.
I was wondering if the leak is on the upper o ring and how to repair this small leak.
Thanks in advance.
Piuric
Name:	air strut vw touareg.png
piuric is offline
post #2 of 4 Old 01-15-2018
Moderator
hedditch's Avatar
Most likely suspect will be a failed o-ring in item #6. The Check Valve...
hedditch is offline
post #3 of 4 Old 01-15-2018
Just as info your diagram is of a 7L shock not a 7P
regards
drag
dragline1570 is offline
post #4 of 4 Old 01-19-2018 Thread Starter
Touareg: 2010 V8
Thank you so much for the help I will try to disasemble it and replace the o rings...
piuric is offline
air suspension , leak
