Air suspension issue - Club Touareg Forums
post #1 of 9 Old 10-25-2018 Thread Starter
2005 v8 165k miles.
Front end not raising. Replaced the pump with a used one thinking maybe mine was bad and seems to work fine.
Just replaced the solenoid valve block. Same problem.
If i swap the front and back lines the front will raise. So if i swap them back to normal, what could be telling the front not to raise?
Any help appreciated.
Qdogg is offline
post #2 of 9 Old 10-25-2018
Multiple v10tdi owner
Blownvette's Avatar
Second Vehicle: 2004 V10 TDI
Module is all I can guess. Maybe the relay?
Blownvette is offline
post #3 of 9 Old 10-25-2018
Have you tried to manually fill each axle via VCDS?
A computer is practically mandatory when trying to diagnose problems with the air suspension.
post #4 of 9 Old 10-26-2018
4ePikanini's Avatar
Touareg: 2005 R5 TDI
check that level sensors are properly attached to the upper control arms. Also check the electrical connectors going to the level sensors are properly connected and not full of moisture/dirt.
2001 Gen3 Di-D LWB - SOLD
4ePikanini is offline
post #5 of 9 Old 10-26-2018 Thread Starter
I haven’t looked yet but do I need to pull the wheels to check the level sensors?
Qdogg is offline
post #6 of 9 Old 10-28-2018 Thread Starter
Left front level sensor is broke. Got one on order. Hopefully that will fix it. Will update when i install. Thanks
Qdogg is offline
post #7 of 9 Old 10-29-2018
Yay! An easy (and relatively inexpensive) fix!
post #8 of 9 Old 11-04-2018 Thread Starter
Sensor installed and all is good. Wish i would have checked this first but now i have a 5 year newer compressor and a new solenoid block and learned about the air suspension system. Hopefully no more issues for a while.
Qdogg is offline
post #9 of 9 Old 11-04-2018
Always, always, always diagnose an issue before throwing money/parts at it. Be a mechanic, not a parts changer.
Glad you got it sorted out.
- OEM air suspension retrofit
- OEM parking heater retrofit
chewblekka is offline
