Add tpms to 2007 touareg. - Club Touareg Forums
post #1 of 5 Old 03-14-2019 Thread Starter
Foxgoku's Avatar
Touareg: 2007 V10 TDI
I have a 2006 touareg that doesnt have tpms on the tires. How difficult is this to add? Can I just install the tpms sensors in the tires and then make a change in vag-com? Or is it more complicated than that? Thanks for the input.
Foxgoku is offline
post #2 of 5 Old 03-14-2019
You would need the TPMS module thats attached to the lower left A pillar, 4 antennas and 4 sensors at each corner, wiring, and vcds coding.
Much simpler and easier to check your tire pressures every so ofter.
- OEM air suspension retrofit
- OEM parking heater retrofit
chewblekka is offline
post #3 of 5 Old 03-15-2019
Or buy an aftermarket kit the next time you buy a new set of 4 tires so the new sensors and valves can be fitted during the change of rubber.
There used to be valve cap pressure indicators.
You set the pressures correctly, then screwed the caps on the tops of which would then show green.
If the pressure dropped the green would be replaced by red.
Of course these only work when you walk round the car!
post #4 of 5 Old 03-15-2019
Xiaomi are making one. Not tested it myself. Mine has the module and I just bought the sensors and the programmer and will be mounting them soon with the wheels/tyres.
Check this video: They are available on aliexpress and maybe amazon.
TRespect is online now
post #5 of 5 Old 03-16-2019
Originally Posted by noobytoogy View Post
Or buy an aftermarket kit the next time you buy a new set of 4 tires so the new sensors and valves can be fitted during the change of rubber. There used to be valve cap pressure indicators. You set the pressures correctly, then screwed the caps on the tops of which would then show green. If the pressure dropped the green would be replaced by red. Of course these only work when you walk round the car!
There are better solutions than that. For ex. I've bought one of these: CARCHET TPMS Tire Pressure Monitoring System with 4 External Sensors Cigarette Lighter The display unit fits perfectly and is at just the right angle when put into the normally hidden cigarette lighter socket that's right under the climatronic unit.
The system works flawlessly, sensors have good battery time, and the display shows the pressure fairly accurately. However, it's still a PITA to remove them every time when you've to put some air in the tires. Well, at least if you also have the theft-resistant nuts installed anyway.
If this doesn't bother you or you think you can use it also without the special nuts, then this product is definitely what you're looking for. It costs the fraction of the factory unit, and works at least as good if not better than that.
Gnits is online now
Just a refresher on the Secrets of the Touareg JAGERVEGAS General Maintenance & Repair 57 02-20-2014 05:31 AM
Parting out dismantled 2006 Touareg , less then 60 miles of use! Gregsparts111 Commercial Posts 20 08-13-2013 01:59 PM
OLD List Of TSB's and Recalls for Touaregs - no longer valid info aircooled General Maintenance & Repair 32 06-11-2008 01:02 PM
2 NEW 2007 VW Touareg V10's FS 13 year vet Commercial Posts 7 02-20-2008 10:45 AM
