Abs, parking error, start stop warning lights - Club Touareg Forums
post #1 of 13 Old 08-07-2018 Thread Starter
Touareg: 2006 V6
Hi folks, my wives 2011 Touareg has multiple warning lights at present. Every thing seems normal. Apart from the lights on the dash. Brakes have been done and brake sensors are fine. Can anyone suggest some other checks I can make?
Johnboy is offline
post #2 of 13 Old 08-07-2018
How is your battery? Low voltage is reported to throw all sorts of codes.
You will have to scan it with VCDS. Not a regular OBDII scanner. And not a generic knock off. The real one from Ross-Tech: Home.
Anything else is a WAG. (Wild *ss Guess)
post #3 of 13 Old 08-15-2018 Thread Starter
Touareg: 2006 V6
I took the vehicle to auto tech, and had a diognostic scan, the technician said the speed sensor needs replacing. Cost $240. Iv booked the job in for latter in the week. But today the warning lights are gone and everything is back to normal...! I’m scratching my head, and ain’t doing anything about the speed sensor in the mean time
Johnboy is offline
post #4 of 13 Old 08-15-2018 Thread Starter
Touareg: 2006 V6
Just used the vehicle again, and all the warning lights are back. I’m not sure what the speed sensor has to do with abs and parking brake errors. So I will take it in and let them change it.
Johnboy is offline
post #5 of 13 Old 08-15-2018
Speed sensor output is used by most systems of the vehicle, including the ABS system. www.engine-light-help.com/speed-sensor
post #6 of 13 Old 08-15-2018 Thread Starter
Touareg: 2006 V6
Just read the link you sent,
Thanks, it makes a lot more sense now, erratic transmission shifts is another symptom, when down hill coasting, which the article touched on. I’m feeling much more reassured about getting the work done now.
Johnboy is offline
post #7 of 13 Old 08-16-2018 Thread Starter
Touareg: 2006 V6
We got the speed sensor replaced, and it has fixed the problem. Running as good as ever. Just clocked 201000 kms
Johnboy is offline
post #8 of 13 Old 08-16-2018
Thanks for the follow up. Glad the problem is fixed.
post #9 of 13 Old 04-10-2019
My 2011 V6 has ABS, Anti Skid and Brake warning lights coming on after a mile .
djtait2 is offline
post #10 of 13 Old 04-10-2019
Post a VCDS scan and we should be able to give you some suggestions.
