295/45/20? - Club Touareg Forums
post #1 of 13 Old 08-02-2018 Thread Starter
Touareg: 2014 V6 FSI
295/45/20?
Does anyone know if a 295/45/20 would fit on a 2014 TDI R-Line without rubbing, etc? The OEM tires are 275/45/20, but looking for something a littler taller/wider if possible and have a good opportunity to pick up a set in 295/45. Thanks!
nala is offline
post #2 of 13 Old 08-02-2018
Scubacruiser's Avatar
Overall diameter would only be 3/4" larger. Speedo would be out 2.38% (too slow). So likely not an issue for rubbing.
Scubacruiser is offline
post #3 of 13 Old 08-02-2018 Thread Starter
Thanks. I'm definitely not worried about the speedometer, just wanted to make sure these would fit.
If anyone else has any insight or opinions, or better yet, actual experience with this tire size, please let me know!
Thanks again!
nala is offline
post #4 of 13 Old 08-02-2018
Touareg: 2012 V6 FSI
I run that size tire on a 20x10 wheel lowered on H&R springs without any rubbing. That said I'm a gasser and not a TDI unfortunately.. I seem to recall an intercooler up in there behind the wheel well liner on older TDIs if i'm not mistaken that could be the difference in possible rubbing.
gtibobvr6 is offline
The Following User Says Thank You to gtibobvr6 For This Useful Post:
nala (08-02-2018)
post #5 of 13 Old 08-02-2018 Thread Starter
Thanks!
nala is offline
post #6 of 13 Old 08-02-2018
If those tyres fit the speedo will be more accurate!
post #7 of 13 Old 08-02-2018
Garticus's Avatar
Touareg: 2013 V6 FSI
Garticus is offline
post #8 of 13 Old 08-03-2018
Remember that apart from the hole in the middle which has to be exact for obvious reasons, tire sizes are nominal and the overall diamater in any size can vary quite a bit by up to half an inch or even more, and that can even apply to to different tire models from the same manufacturer.
So if you are on the limit for the tire/wheel opening on the car you need to be thinking along the lines of a trial fit in order to make sure that there is no rubbing.
post #9 of 13 Old 08-03-2018
gophurr's Avatar
Based on my own research I would suggest going with a 295/40/20 just because it is a more common tire size, so you will have a great variety of choice for tires, possible better pricing, and could be less hassle if you ever need to replace 1 or 2 tires.
Honestly I don't think there is much to gain from a 295/45/20 versus 295/40/20. The middle number stands for aspect ratio (%). For example 275/45/20 the sidewall is a 45% aspect ratio of 275, likewise 295/45/20 is 45% aspect ratio of 295.
gophurr is offline
post #10 of 13 Old 08-03-2018 Thread Starter
Thanks for all the feedback. I was not looking at this size in particular, just came across a really good deal on a set of barely used tires in this size so wanted to get input since I can't "test fit" without buying...
nala is offline
