‘14 front differential oil capacity? - Club Touareg Forums
post #1 of 1 Old 04-09-2019 Thread Starter
On my current 2014 Touareg just drained the front differential and refilled with correct VW gear oil.
I filled until it started to run out the fill hole, used almost an entire quart.
Now it is making an odd sound under acceleration, sort of like gear rumble or a very low pitched bearing howl. Until this drain and refill the front diff has not made a sound that was abnormal. The last ‘14 I had had a differential bearing go so I’m familiar with the sound it made. This is not the same.
Wondering if I over filled it. Couldn’t find a definitive spec on capacity.
Thanks for info that anyone can share.
Mech644 is offline
DIY Oil Change for 4.2L V8 Mike Touareg DIY and Technical Info - DO NOT POST NEW THREADS ASKING QUESTIONS 175 09-27-2017 09:51 AM
Oil suggestion for deleted emissions TDI Marbles Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 52 04-12-2017 12:05 PM
oil cap says Castrol, can I use Mobile 1 ? vanfx Gasoline Engine, Electric Hybrid and Powertrain | V6, V8, W12, FSI 16 10-20-2013 01:41 PM
DIY: 2010 V6 TDI Oil Change - Extraction Method DCC Touareg DIY and Technical Info - DO NOT POST NEW THREADS ASKING QUESTIONS 37 02-25-2013 12:44 PM
