01772 - G291 - Implausible signal - Club Touareg Forums
post #1 of 4 Old 04-16-2019 Thread Starter
Hi everyone!
My '04 V10 (231k km) with air suspension has been throwing this code intermittently for the past six months:
I've put many km's on the car in the meantime and haven't noticed any real issue...
One or twice the car seemed to run a little high and sometimes it takes a while for the car to be fully raised (when turning the ride height dial). Also, the compressor can sometimes take a little while to build up pressure when I'm filling tires.
I checked the forum - information overload - and cannot find any "resolved" posts.
Any advice?
Best,
VD-CH
VD-CH is offline
post #2 of 4 Old 04-16-2019
4ePikanini's Avatar
Touareg: 2005 R5 TDI
replace the pump's cylinder head and piston ring.
2001 Gen3 Di-D LWB - SOLD
4ePikanini is offline
The Following User Says Thank You to 4ePikanini For This Useful Post:
VD-CH (05-22-2019)
post #3 of 4 Old 04-17-2019 Thread Starter
https://www.youtube.com/watch?v=BD6N98mrM1c
I take it you had the same error message?
VD-CH is offline
post #4 of 4 Old 05-22-2019 Thread Starter
Replaced the pump cylinder head and piston ring yesterday. Stupidly, I took out the air hoses from the compressor before working and the car was on jack stands (only front axle) so the rear suspension was down completely and when I lowered the car from the stands it was uneven.
Started/turned the engine off a couple of times and cycled it through high/low comfort/sport and it seems to be reasonably level again (front a little bit lower than the back, less than 3cm difference). Also not throwing any errors messages anymore...
Thanks for everyone's input, especially @4ePikanini
VD-CH is offline
New to me 05 V8 - throwing codes mk1justin General Maintenance & Repair 45 10-24-2018 05:51 PM
2004 no ecm communication, help! gamerman1111 General Maintenance & Repair 6 07-20-2017 09:02 PM
Intro and Fault Codes Galore... slcousin General Maintenance & Repair 5 02-13-2016 10:33 PM
vagcom scan help! electrical problem joker VAG-COM 4 12-28-2012 01:55 PM
Differential lock rear, implausible signal? JSR2000 General Maintenance & Repair 2 12-21-2012 01:59 PM
