Where is the Auxiliary water pump on the Touareg 4.2 - Club Touareg Forums
post #1 of 3 Old 03-03-2019 Thread Starter
I have an over heating issue on my Touareg. I've changed the thermostat and checked the water pump for proper operation and everything is fine there. I can hear bubbling coming from the coolant fill tank and the hose leaving the coolant tank is getting super hot and have the suspicion the auxiliary water pump failed or the heater core is clogged. I have been trying to find a diagram or info about someone else having this issue. I can't figure out where the line from the coolant tank goes on the back side of the engine. Does anyone have info?
NavyV8Touareg is offline
post #2 of 3 Old 03-04-2019
FYI
Auxiliary Water Pump: Description and Operation
Recirculation Pump, Engine Codes AXQ and BHX
‹› The Recirculation Pump (V55) is installed in the left front wheel housing behind the wheel housing liner.
Auxiliary Water Pump: Service and RepairRecirculation Pump, Engine Codes AXQ and BHX
Removing-Discharge coolant circuit.-Remove the bracket - 1 - from the body and remove the Recirculation Pump (V55) - 2
post #3 of 3 Old 03-04-2019
Are you losing any coolant? Pressure test the system. I would check for leaks in your cap and coolant reservoir. If any issues with interior heat, I would suspect heater core. Are your cooling fans operating properly? On my 04 V8, my coolant temp sensors failed and car ran hot with electric fans running after engine was off.
johnk is offline
Touareg V10 TDi Tandem Pump change without dropping the engine TouaregV10on33s Engine, Transmission and Exhaust 28 05-02-2019 08:44 AM
2015 Canadian Touareg 7P Webasto parking heater retrofit chewblekka Touareg DIY and Technical Info - DO NOT POST NEW THREADS ASKING QUESTIONS 77 02-12-2019 07:16 AM
Secrets of the Touareg - Touareg2 dnyed Drivers Lounge 451 04-10-2017 01:03 PM
150,000 miles on original timing belt and water pump MarkLWarner General Maintenance & Repair 49 09-18-2010 12:23 PM
