V8 treg valve cover gasket replacement - Club Touareg Forums
post #1 of 6 Old 03-28-2019 Thread Starter
Hey there, has anyone replaced the valve cover gaskets on a v8 treg ? which brand used and best price as well...there are many different brands and would like to buy a decent quality brand. Thanks in advance!
FLbronzeback is offline
post #2 of 6 Old 03-28-2019 Thread Starter
Also is it required and also should a gasket sealant be used when replacing the gaskets?
post #3 of 6 Old 03-28-2019
You'll need to use a high temperature sealant when replacing the gasket.
Sent from my HTC 10 using Tapatalk
Scorror is offline
post #4 of 6 Old 03-28-2019
I replaced mine on my 08 V8 fsi.....very straightforward process. I did not use any sealant (earlier v8's may be different) ...I used OE VW/Audi gasket set from my local dealership. Given the rather low price (if I recall correctly, under $40 for the set) it was a bit of a no brainer to stick with OE.
be sure to adhere to proper torque specs as well as the proper torque sequence.....you'll be fine.
n8henn is offline
post #5 of 6 Old 03-28-2019
nikoloz's Avatar
i changed mine on my 05 V8 and no sealant is needed if you are using new parts, also used OEM parts. no issues at all
nikoloz is offline
post #6 of 6 Old 03-28-2019 Thread Starter
Awsome does anyone happen to know the torque spec sequence that's recommended?
2004 VW Touareg Valve Body / Valve Chest Replacement HIRacing General Maintenance & Repair 68 11-28-2017 06:12 AM
HELP 2008 Touareg V8 Valve Cover Passenger Side Agentsnake General Maintenance & Repair 0 04-29-2016 01:06 PM
2008 V8 pcv valve cover. shaolin Engine, Transmission and Exhaust 2 04-21-2016 02:41 PM
Help! Replacing valve cover gaskets and need torque specs! slavik1988 General Maintenance & Repair 0 12-11-2014 09:48 AM
Issues after Valve Body replacement Jayrfb New Member Introductions 4 09-12-2012 09:48 AM
