V10 voltage drop on start up - Club Touareg Forums
post #1 of 16 Old 02-22-2019 Thread Starter
Our V10 has a serious voltage drop issue on start up. It will not start, until you use the emergency start. Batteries are fine. Any ideas?
Xelam is offline
post #2 of 16 Old 02-22-2019
Define "batteries are fine"! How old are they? Have they been tested with a battery tester? Or did you just check their voltage? If the latter, then how - with the batteries disconnected, or while on circuit?
Gnits is online now
post #3 of 16 Old 02-22-2019
In simple terms, the rear battery is the starter battery assisted by the front battery which runs the consumables.
If the rear battery is duff then the front battery will shut down various things so it has enough oomph to take over starting the car.
From what you describe, your rear battery is a dud.
There may be something else going on but I'd suggest you try another battery in the rear first to see if that resolves the issue.
Here's the VW Self Study Programme for the electrical system which explains everything in detail:
http://www.volkspage.net/technik/ssp/ssp/SSP_298_d1.pdf
post #4 of 16 Old 02-23-2019 Thread Starter
Cheers for your quick replies. I had the front battery tested at the shop, they confirmed that it tested fine. However, I didn't realise that the muppets didn't test it under load. I checked it myself this morning, turning the key on with the voltage meter, watching the voltage fall off. So I disconnected the battery and sure enough, it didn't hold 13 volt. So once I replaced it with another battery, problem fixed. Glad it appeared to be an easy solution in the end.
Xelam is offline
post #5 of 16 Old 02-23-2019
Check the rear battery under load also.
Fourdiesel is offline
post #6 of 16 Old 02-23-2019
In short: they didn't test it at all. Whatever they did can not be considered "testing" the battery.
Gnits is online now
post #7 of 16 Old 02-26-2019
IMO your rear battery at fault!
lgibson is offline
post #8 of 16 Old 02-27-2019
Same problem this morning. Didn't drive my car for 9 days and now it won't start without the key in the ignition and switching to the other battery.
Front battery was replaced Q4 2017
Back battery was replaced Q4 2012 (I think we've found our culprit)
I'm about to measure the batteries with my multimeter... What readings should I be getting?
Thanks!
VD-CH is offline
post #9 of 16 Old 02-27-2019
What is important is the voltage drop during the starting sequence. If you log group 7 in address 09 central electrics you will see how both batteries show maximum voltage drop around 2:39 seconds into the aequence. With good batteries in cold weather I have recorded 9.9 front and 9.6 rear at that moment ans still started successfully. If you read below these numbers you need to replace one or both batteries. This is how I decide when to replace batteries.
lgibson is offline
post #10 of 16 Old 02-27-2019
Thanks for the reply lgibson.
I measured the back battery in the meantime, 12.91V with the engine off, 13.91V with it running and 13.64V with it running while having the SATNAV and my high-beams on.
Sorry for being a newbie, but I'm not sure sure what "group 7 in address 09 central electrics" means?
VD-CH is offline
emergency start , low voltage , no start , starting issue , voltage drop
Electrical consumers error / voltage drop / high temperature - all related? JimmyB General Maintenance & Repair 11 10-08-2017 02:49 PM
06 Touareg TDI V10 - Crans but will not start. smrtalec Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 21 08-20-2017 08:27 PM
V10 battery & keyless start trigger General Maintenance & Repair 11 10-03-2014 01:15 PM
Diagnosing battery drain issue, voltage drop results TUNINGBYAMG Mobile Electronics and In Car Entertainment 47 08-08-2014 03:59 PM
Where can I find the changes made on the Touareg 2? axg1040 General Maintenance & Repair 8 09-27-2007 09:02 PM
