Touareg won’t start, faulty engine speed sensor - Club Touareg Forums
post #1 of 13 Old 03-10-2019 Thread Starter
So ive had my 2008 touareg tdi 3.0, 233000 km for about 9 months. Its treated me really well and i have driven it a lot all over eastern europe. i noticed over the last month it was taking more cranks for it to start. i attributed it to being colder weather. halfway through my last long trip my wife and i stopped for lunch and as literally ad shes saying i love this car..it wouldnt start. it would crank but not start. next to the restaurant was a car service place so they came over and said it was the battery. i didnt think that was right but they gave it a jump and i headed to the service shop. weird. got the oil changed as it was due and had them check the battery. sure enough the battery was tested and proved good, but apparently the engine speed sensor is faulty and as a result the car would not start. admittedly im not a car expert and the local languages are not my first language so im not sure if they meant the camshaft sensor but im pretty sure they said engine speed sensor. anyways, they said they would order the part and in ten days would have it. i drove back to my village a few hours away and now predictably the car wont start. i guess my question is why is the car starting with jumper cables and is it normal to do that? i only need it to start one more time so i can drive it back to the city and get this sensor replaced.
Albania/Kosovo
drewbreezy is offline
post #2 of 13 Old 03-11-2019
Often the speed/crank position sensors act up when the engine is warm/hot, so the car will start once the sensor cools off. My guess is that the time it took for you to get the jumper cables set up was enough to let the sensor cool off.
johnk is offline
post #3 of 13 Old 03-11-2019
BenF's Avatar
Yeah, crank angle sensor usually stuffs up while you're driving. Not so much hard-starting symptoms. Almost take a guess with fuel pump maybe?
Ben.
BenF is offline
post #4 of 13 Old 03-11-2019
Speed sensor went kaput on mine when driving then stopping at a traffic light. waited 5mn then it started fine. a vcds scan showed sensor g28 intemittent comm. I replaced it and so far so good.
TRespect is online now
post #5 of 13 Old 03-11-2019 Thread Starter
Ben.
I also thought maybe it could be the fuel pump. When I took it to the shop and
they ran their diagnostic however they definitely indicated it was the engine speed sensor.
Albania/Kosovo
post #6 of 13 Old 03-11-2019 Thread Starter
Im just hoping I can find a way to get it started with a jump or pray to the touareg gods that it will start once the replacement part arrives.
Albania/Kosovo
post #7 of 13 Old 03-11-2019 Thread Starter
Once its started and running I havent had any problems of the engine cutting while driving, only the startup has given me problems. Hoping its not the full pump and Im replacing the engine sensor in vain
Albania/Kosovo
post #8 of 13 Old 03-11-2019
Engine speed sensor can equal no start or random starts. It just depends. Often but not always shows up as a hot restart problem.
Crank position sensor can equal long starts, but it should still consistently long start.
If a fuel pump goes bad (you have two), it is different things depending on if you have less then 1/4 tank or more then 1/4 tank of fuel. A big fuel pump tipoff is it changes when more or less then 1/4 tank.
If fuel filter gets clogged, you will see the fuel trim constantly adding fuel.
nickyt is online now
post #9 of 13 Old 03-11-2019
Off-topic but I'm having a rich mixture error (-25 trim) and I'd like more details or info/links about this statement.
I'm looking into this issue and will be testing the fuel pumps soon.
post #10 of 13 Old 03-11-2019
I have seen it add fuel when the fuel filter was clogged. No idea about it removing fuel. Dirty Air Filter or MAF comes to mind. This 3 page article discusses it.
autoserviceprofessional.com/article/94982/Fuel-trim-How-it-works-and-how-to-make-it-work-for-you?Page=2
DIY - Engine Speed Sensor G28 V6 TDI P0322 Ewic33 Touareg DIY and Technical Info - DO NOT POST NEW THREADS ASKING QUESTIONS 6 11-20-2017 07:24 AM
Just a refresher on the Secrets of the Touareg JAGERVEGAS General Maintenance & Repair 57 02-20-2014 05:31 AM
R5 Heart transplant 4ePikanini Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 12 01-18-2014 05:55 AM
