Touareg 2011 All 12v lighter outlet shows 0.8V - Club Touareg Forums
post #1 of 8 Old 05-28-2019 Thread Starter
Hi all,
All my lighter outlet are malfunctionning. I tested the 4 outlet with a lighter plug tester and they all show the red light (malfunction). I then checked the voltage and they all have 0.8V. I checked the fuses (fuse 38 and 39, 15A) and they are ok. What is the problem?
Thanks,
Phil
grandschmu is offline
post #2 of 8 Old 05-28-2019
First, check the tester in another vehicle and make sure it works. Next you have to start chasing wires, verifying both the voltages and the grounds.
post #3 of 8 Old 05-28-2019
Was the ignition on?
post #4 of 8 Old 05-29-2019 Thread Starter
Yes, I checked the tester and it works ok. Tomorrow I'll check the voltage directly at the #38 and 39 fuse, I think it is the lighter plug fuses.
post #5 of 8 Old 05-29-2019 Thread Starter
Yes, the car is running
post #6 of 8 Old 05-29-2019 Thread Starter
Is there a kind of voltage controller or current limiter on the circuit? If the voltage at the fuse is also 0,8v, where can be the problem?
post #7 of 8 Old 05-29-2019
If the voltage at both sides of the fuse is 0.8V, then the issue is upstream of the fuse. ie, between the fuse and the wiring that leads back to the battery / alternator.
Is there anything else electrical not working?
post #8 of 8 Old 05-30-2019
Check voltage with a direct ground to battery or chassis first!
Gnits is offline
