Touareg 2 Parking Sensors RED light - Club Touareg Forums
post #1 of 13 Old 06-28-2015 Thread Starter
Touareg: 2009 V6 TDI
Hi,
I have annoying Red ling on Parking assist display
I can hear faint clicks on all Sensors with the key on in Forward , Reverse.
VAG output
6 Faults Found:
00429 - Left Front Parking Aid Display (Y13)
009 - Open or Short to Ground
00430 - Front Right Parking Aid Display (Y14)
00431 - Rear Parking Aid Display (Y15)
004 - No Signal/Communication
any thoughts?
m0rhaven is offline
post #2 of 13 Old 06-28-2015
Moderator
hedditch's Avatar
Yes, I recommend you check the condition of the 14 PIN connector between the front bar and the right front wheel arch. Accessible if you remove the lining in front of the wheel. Good chance you have a dodgy connection. If you do then its much less expensive than the alternative of replacing sensors.
Good luck..
Stuart..
hedditch is offline
post #3 of 13 Old 06-28-2015
Whilst you have the lining out, check that the bulkhead drain is clear too as preventative maintenance.
post #4 of 13 Old 06-28-2015 Thread Starter
Thanks will look at this.
Right as in passenger side correct?
m0rhaven is offline
post #5 of 13 Old 06-29-2015
Moderator
hedditch's Avatar
Only in your world ............................Trust me the right hand side when you a sitting in the car.
hedditch is offline
post #6 of 13 Old 06-29-2015 Thread Starter
checked out connector. all looks up good.
where is the module in the trunk exactly?
m0rhaven is offline
post #7 of 13 Old 06-29-2015
themedic's Avatar
Touareg: 2008 V6
I had this problem as well, the truck was a little dirty, took it to the wash used a pressure hose on the front of the sensors and under the body. This solved the error messages for me. There was a lot of road grim under the truck. Seems silly but it might work.
themedic is offline
post #8 of 13 Old 06-20-2017
Lux Magic's Avatar
Touareg: 2010 V6
Originally Posted by m0rhaven View Post
Hi,
VAG output
6 Faults Found:
any thoughts?
Have the same symptoms, but haven't scanned yet. Strange that I have the sensors all clicking but no communication I guess. What was the outcome of this I wonder.
Lux Magic is offline
post #9 of 13 Old 06-21-2017
Scubacruiser's Avatar
Mine will sometimes turn red when waiting at a traffic light. I've been attributing it to the in-pavement sensors for the signal lights.
Scubacruiser is offline
post #10 of 13 Old 10-07-2017
Lux Magic's Avatar
Touareg: 2010 V6
I know this is an old thread...But I had an issue when it rained and the parktronic wouldn't work. The first time I heard a trick of listening to each sensor for a click. All had clicks but still not working, Then a few days later it was fine, after they dried out (or so I thought). Fast forward a few more weeks and more rain and again they wouldn't work. Just the red lights on the dash. No clicks this time. Scanned with VCDS and all of my sensors were bad. I knew they all couldn't be bad, so I knew it was the module. (little hint, as long as the module has power VDCS thinks the module is good) Swapped out module and all is good again. Module is on left side of trunk behind access panel all the way on the bottom. You need to pull away the whole panel on the left. It was kind of a bear, but took me an hour and change to do.
