Tachometer - Club Touareg Forums
post #1 of 9 Old 02-21-2019 Thread Starter
Tachometer
Hey guys,
The tachometer on my 2010 V6 will not zero out. When the ignition is off, it sits at 5K RPM and once I start the truck it only goes up from there. Has anyone else had this issue and is there an easy fix?
NotFromHere is offline
post #2 of 9 Old 02-21-2019
Never read of this before over the past 10 years.
post #3 of 9 Old 02-21-2019 Thread Starter
I couldnít find any related threads, so I figured this problem may be unique to my truck.
I donít require the tach, but it is there and I am a bit obsessive about everything working properly.
post #4 of 9 Old 02-21-2019 Thread Starter
Image of tach with vehicle not running!
post #5 of 9 Old 02-21-2019
Scubacruiser's Avatar
I used to design instrument clusters for construction and ag equipment. Usually there is a zeroing procedure at time of manufacture, but nothing available once the unit is installed. Zeroing is either overdrive the pointer against a pin while it slips on the motor shaft, or setting zero with a jig. Our tachs have no zero pin. Some stepper motors have an internal zero position, but most do not.
I would say that your pointer became loose at some point and slipped. Now it is stuck with the motor in the correct zero position, but the pointer has moved. The only way to fix this would be to open the cluster and move the pointer manually, then pushing it on solidly.
Scubacruiser is offline
post #6 of 9 Old 02-21-2019
What does the tach display when the engine is running?
- OEM air suspension retrofit
- OEM parking heater retrofit
chewblekka is offline
post #7 of 9 Old 02-21-2019 Thread Starter
6400 RPM at idle
post #8 of 9 Old 02-21-2019 Thread Starter
6400 RPM at idle
post #9 of 9 Old 02-21-2019 Thread Starter
So, there goes any hope of a quick fix!LOL
Thank you
