System Fault Workshop 07 Touareg - Club Touareg Forums
post #1 of 7 Old 10-08-2018 Thread Starter
Any idea what this error means?
gxavier6 is offline
post #2 of 7 Old 10-08-2018
You need to scan the car with VCDS to get the fault codes.
post #3 of 7 Old 10-08-2018 Thread Starter
Yah I guess but every time it goes off it’s usully after work or when the shops already closed. Should it be in history?
gxavier6 is offline
post #4 of 7 Old 10-08-2018
New2Tregs's Avatar
Yes any codes should store in your history unless someone has cleared them or the battery was disconnected then reconnected after a bit.
What NoobyT is referring to with VCDS is a Ross Tech tool you can buy and use to scan codes yourself. It's a very handy tool that most people should have in their toolbox. That way you can scan codes (and much more) any time it's convenient for you.
New2Tregs is offline
post #5 of 7 Old 3 Weeks Ago Thread Starter
Bad headlight 2007 Touareg
So my headlight doesn’t work. I replaced the bulb twice but still doesn’t work. The high beams and small yellow bulb work fine but the headlight doesn’t. Anyone ever have this problem. You think it’s the fuses? Where are they?
gxavier6 is offline
post #6 of 7 Old 3 Weeks Ago
Nope.... both mine work....
could be.......
check fuse panel
post #7 of 7 Old 3 Weeks Ago
Multiple v10tdi owner
Blownvette's Avatar
Second Vehicle: 2004 V10 TDI
If you have the HID headlights it most likely is the ballast. I picked up a used set on eBay as the aftermarket cause headlight errors on the dash. Get a VCDS scan and you will know more for sure as to what is wrong.
Blownvette is offline
