System Fault, Check engine light, ABS, Brake - Club Touareg Forums
post #1 of 3 Old 3 Weeks Ago Thread Starter
Recently our 2009 Touareg v6 has been having the System Fault dash message come up along with Check engine Light, ABS, Brake, and several other alerts. I have been through and checked the wiring for corrosion and also replaced the battery, and verified charging system is good. Outside of that it's intermittent, usually at first startup, attached are the vcds codes from several modules. Any help would be greatly appreciated.
setheikom is offline
post #2 of 3 Old 3 Weeks Ago
Multiple v10tdi owner
Blownvette's Avatar
Second Vehicle: 2004 V10 TDI
First thing I would do is load test the battery. Then maybe check the ecu ground if still having problems. Just guessing on my part about the ground.
Blownvette is offline
post #3 of 3 Old 3 Weeks Ago
Do you have an aftermarket radio unit?
If so remove it, disconnect the battery for a few hours and scan again.
If not you should start hunting for gremlins in the wiring, maybe getting secondhand used ebay modules to do trial and error troubleshooting till you find the bad one. Most likely you have a wiring issue.
Any water leaks recently?
TRespect is offline
