System Fault - Club Touareg Forums
post #1 of 2 Old 02-26-2019 Thread Starter
System Fault
My Volkswagen Touareg year 2007 3.6 car is starting everything is functioning but gives a system fault and thus
blocks the gearbox so cannot be driven. We checked and it looks as if there is somewhere a short circuit and thus causing sensors not to work proper anymore.
The car does not recognise the key at least it says so key symbol but you can still start the car with the key so the key is not the problem.
ABS light is on and red brakelight is flashing. Car blocks transmission. Also the light for low high gearing is on.
The OBD gives many faults but I think that is logical as there is a system fault. OBD was also refused entrance to read many times.
I am living in St Maarten and the car has survived Irma last year. Such a hurricane has a huge impact even years later so it is possible
that the bitch of a hurricane killed my car after all. But who knows and somebody has experienced the same and might know a solution or has an idea.
Is there for example a way to de-block the gearbox/transmission?
Thanks in advance
beekvanjan is offline
post #2 of 2 Old 02-27-2019
mtnride's Avatar
Touareg: 2007 V8
Second Vehicle: 2007 V8
Beekvanjan, check the 3 factory wire splices in wire loom that runs under drivers side door sill
(assuming you have left hand drive). Click image for larger version
ID:	221385These splices are a known issue and are prone to deteriorate from water in that area.
mtnride is offline
Steering Locked Car wont start sean kennedy Brakes, Steering, Suspension, Wheels and Tires 3 07-11-2018 11:50 PM
OBDEleven Scan Matttregg88 General Maintenance & Repair 1 05-02-2017 09:28 PM
Engine Stalling, Generator Warning pcotten General Maintenance & Repair 30 06-10-2016 03:37 PM
Post your output scans of your Touareg2 aircooled VAG-COM 19 10-27-2012 09:17 AM
Troubleshooting Auto HVAC Fault Codes Danville VAG-COM 8 08-31-2012 03:27 PM
