Passenger side wiper not pressed to window - Club Touareg Forums
post #1 of 8 Old 02-22-2019 Thread Starter
Hi. I have read many similar posts about problems with the passenger side wiper not pressing hard enough against the windshield. I have new EOM blades, new linkage & lubricated springs (as others have suggested) but have found that the problem seems to be related to a slightly loose bolt on the passenger side of the linkage. It is the exposed nut and bolt on the left side of the picture of the wiper linkage (picture taken with hood raised). You can tighter the bolt (only 1/2 turn or so) and the wiper will work for a couple of swipes then the bolt loosens and the wiper does not press against the windshield again. Anyone with similar experience and better yet a solution?
shady acres
Gmwarren is offline
post #2 of 8 Old 02-22-2019
There's supposed to be a washer under the nut. Do you have that? Part number is "7L0 955 345".
Gnits is offline
post #3 of 8 Old 02-23-2019 Thread Starter
no washer
Thanks for the quick reply. Just had a look. There is no washer but the bolt has a washer-like flange. This is a 2006 V8.
Taking the nut off did reveal more about what might be the problem. The threaded bolt has a flat spot and it looks like the metal linkage is supposed to have a matching flat spot but what I can see is more like gouged metal near the base of the flat spot (hope it shows up in the photo). Does that prompt and further ideas?
I will try a washer and see if it helps. The idea makes sense.
Thanks!
shady acres
Gmwarren is offline
post #4 of 8 Old 02-23-2019
Seems like your linkage is partially destroyed. It should look like this:
Gnits is offline
post #5 of 8 Old 02-23-2019
Obviously your problem is that because of the partially destroyed slitting the linkage is not moving tightly with the driver bolt anymore, but there is now some play between the two, which causes the nut to loosen up (as that will stick to the linkage, while the bolt will turn in it, "unscrewing" the nut off itself).
You won't be able to fix this, unless you can somehow ensure that the driver bolt and the arm will move again tightly together, with no play. I'm not sure how you could achieve that though without replacing the arm with the linkage.
Gnits is offline
post #6 of 8 Old 02-23-2019 Thread Starter
Super great response. Thanks so much and thanks for the picture. The problem is clear now. I am hoping you had a spare linkage lying around and did not disassemble yours just to illustrate the problem.
Gmwarren is offline
post #7 of 8 Old 02-23-2019
No worries. This isn't my linkage, and not even my picture. I just googled it.
Gnits is offline
post #8 of 8 Old 02-24-2019
Tightening the nut wiyhout the missing washer may have messed it up unfortunately.
2006 Touareg V10TDI white smoke under hood passenger side. Ale Stankowicz Gasoline Engine, Electric Hybrid and Powertrain | V6, V8, W12, FSI 0 05-14-2018 11:38 PM
Operation of heated side mirrors and heated rear window of the car tg123 General Maintenance & Repair 2 12-23-2017 11:34 AM
2011 Passenger Window Switch replacement hexcor General Maintenance & Repair 0 07-25-2017 05:56 PM
Water Leak, Passenger Side Footwell, Near Pollen Filter Housing volkswagendude General Maintenance & Repair 20 05-11-2016 08:23 AM
For Sale: Passenger side or rear window switch - New in package ColumbusTouareg Classifieds 1 04-10-2011 09:10 AM
