P261C - Aux Coolant Pump - Club Touareg Forums
post #1 of 8 Old 02-28-2019 Thread Starter
Touareg: 2013 V6 FSI
I need some help please. I tried to search for this code and not getting much help. I have replaced the aux coolant pump but with the cheap $80 Chinese one from ebay. I replaced it, topped off coolant, clear the codes and it comes back. I have only really seen the P261B code online. I have verified all the fuses in the front half of the fuse box need to the brake reservoir. I see on the fuse diagrams online about a possible relay for the pump but can't find it. Anyone seen this or have suggestions?
1 Fault Found:
12351 - Coolant Pump 2
P261C 00 [237] - Short to GND
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 172163 km
Date: 2019.02.06
Time: 18:19:33
Engine speed: 1158.50 /min
Normed load value: 22.4 %
Vehicle speed: 52 km/h
Coolant temperature: 93 C
Intake air temperature: 6 C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.559 V
Unlearning counter according OBD: 40
Relative load value: 16.36 %
Readiness: 0000 0100
If I reset, it comes back after about 2 drives.
kickboxin is offline
post #2 of 8 Old 03-03-2019 Thread Starter
Any suggestions???
post #3 of 8 Old 03-03-2019
Start checking the wiring. It seems unlikely you have two bad pumps in a row. The odds would be that the error is not the pump, but something else in the circuit.
post #4 of 8 Old 03-03-2019
gazaflash's Avatar
I would check the wiring. Sounds like that is the culprit. If you have a tone generator, it can find bad spots in wiring harnesses easier.
gazaflash is offline
post #5 of 8 Old 03-03-2019
Check fuses 10 and 12 in the underhood fuse box. Check relay #6. Attached are the wiring diagram and relay location.
- OEM air suspension retrofit
- OEM parking heater retrofit
chewblekka is offline
post #6 of 8 Old 03-03-2019 Thread Starter
Many thanks. I checked the fuse but not the relay. I was searching a while trying to find where it was. Now I just need the get the wiper off to access the back or that fuse box.
post #7 of 8 Old 03-07-2019 Thread Starter
Thanks for the info. I got the wiper arm off and got access to that fuse box. I don't have a relay or even wiring for the relay at R5 or R6. I am wondering if I should be looking for the relay J708 from the wiring diagram. I just am not sure where to find that relay.
ID:	221587   Click image for larger version
post #8 of 8 Old 03-11-2019 Thread Starter
Does anyone know where the J708 relay is? Also is it safe to assume the aux water pump is the same as the recirculating water pump? Don't tell me this car has 3 water pumps.
2015 Canadian Touareg 7P Webasto parking heater retrofit chewblekka Touareg DIY and Technical Info - DO NOT POST NEW THREADS ASKING QUESTIONS 77 02-12-2019 07:16 AM
Can someone advise on a coolant flush for a TDI 2013 javijavit General Maintenance & Repair 1 08-22-2016 01:53 AM
Water pump & coolant replacement jindandy Australia & New Zealand 8 06-14-2016 01:29 AM
Coolant pump relay short to ground non-sense Tonycrd General Maintenance & Repair 2 05-06-2015 07:24 AM
R5 Coolant Pump Replacement paragon70 General Maintenance & Repair 5 01-18-2015 11:09 PM
