Oil change - drain or suck? - Club Touareg Forums
  • 1 Post By RocketTech
post #1 of 7 Old 04-26-2019 Thread Starter
Send a message via Skype™ to JMGTreg
What are most people doing for oil changes on the boards. I've been draining oil the old fashioned way for decades, putting my vehicles on a ramp to make access easy. But as I get older, the thought of crawling on the ground has far less appeal. So I'm thinking of getting a oil vac canister to do my first oil change on my 2014 TDI. The only negative I see with the vac unit, is that I'll need to get a larger capacity version given the amount of oil in the TDI.
JMGTreg is offline
post #2 of 7 Old 04-26-2019
Pump works well fo me. Just ensure the oil is warm. The tube is small so you might have to buy a smaller one. Luckly I already had it. Google it. There is a nice video with extraction also find the link I have posted in here a few weeks ago
Francesco Mosca is offline
post #3 of 7 Old 04-26-2019
13th VW's Avatar
Touareg: 2013 V6 FSI
I've wondered the same thing. I use a vac unit on my Tiguan which has a cartridge filter accessible from the top. I get out exactly 6 qts, replace the filter and I don't drip a single drop. However, my 2013 Tig with the VR6 has a cartridge filter only accessible from the bottom. I put the car up on ramps which means the car will be at quite the angle, so I wonder how much oil I would leave behind in the sump.
'56 Beetle (still have)
'65 Beetle
'69 Ghia (wish I still had)
'73 Super Beetle
'77 Beetle Convertible
'82 Quantum
'85 Vanagon
'91 Jetta Carat
'93 Eurovan (2)
'99 Jetta TDI (son has)
'03 Passat (gave to other son at 185K)
'13 Touareg VR6
'18 Golf Alltrack SE (VW repurchased)
'19 Tiguan SEL-P
13th VW is offline
post #4 of 7 Old 04-26-2019
I use LiquiMoly Engine Flush and drain it through a Fumoto drain valve on ramps.
Ragman likes this.
2016 Touareg 3.0 V6 TDI Lux
2018 Passat 2.0 TSI R-Line
RocketTech is offline
post #5 of 7 Old 04-27-2019
New2Tregs's Avatar
It's just me and I could be wrong, but I thought that draining them while warm was much better than the suction method as any residuals would be drained out with the oil as well.
New2Tregs is offline
post #6 of 7 Old 04-27-2019
I think that's an argument that's going to have plenty of supporters on both sides. There's no doubt suctioning from up top is more convenient, and an engine flush can be used to loosen and suspend more crud. But you can't do the full inspection from up top- several inspection items need to be done from under the vehicle.
At the end of the day, it's your vehicle- do what you feel most comfortable with.
post #7 of 7 Old 04-27-2019
I've been using an extractor for years. but some cars you need to get under to change the filter anyways, so I usually drain those.
I personally run Snow tires on dedicated rims (on all my vehicles) and swap them myself- gives me a great chance for biannual inspection while raised.
mpls is offline
DIY Oil Change for 4.2L V8 Mike Touareg DIY and Technical Info - DO NOT POST NEW THREADS ASKING QUESTIONS 175 09-27-2017 09:51 AM
DIY: 2010 V6 TDI Oil Change - Extraction Method DCC Touareg DIY and Technical Info - DO NOT POST NEW THREADS ASKING QUESTIONS 37 02-25-2013 12:44 PM
Oil Change & Filter V6 3.2 Auto Touregger Touareg DIY and Technical Info - DO NOT POST NEW THREADS ASKING QUESTIONS 0 12-13-2009 07:29 AM
DIY V6 Oil Change writeup vitaminB5 General Maintenance & Repair 10 10-22-2006 05:38 PM
