O6 V10 TDI Oil Leak - Club Touareg Forums
post #1 of 6 Old 2 Weeks Ago Thread Starter
O6 V10 TDI Oil Leak
Has any V10 owner experienced an oil leak in the valley of the engine? Both times I've been in there trying to track it down theres a large pool of oil under where the alternator sits. I've replaced just about every oil orifice I could think of in there. I'm wondering if anyone knows if the seal where the alternator gear meets the engine block could cause this? If so is it even replaceable with the engine in the car. It looks like I could get the gear off im just afraid it may mess up the timing pulling the bolt out. The seal is like 30 bucks at the dealer but he asked the technicians and none of them had any idea about changing it. In the picture its the pully gear that mates with the rubber coupling coming off the alternator. Any advice would be appreciated. I'll also be posting a DIY in the near future of walnut shell blasting these nasty looking intake ports, every single one of them has probably an 1/8" of carbon build up on the ports and valves and its causing me to have misfires and horrendous fuel economy (at least im hoping so).
ID:	224035   Click image for larger version
Mitch_moho is offline
post #2 of 6 Old 2 Weeks Ago
Is that the BKW engine? What year? Doesn’t look like what I remember from my generator replacement last year. Your oil filter stand is not leaking is it? My drive seal was in great condition at 120k. You would need to buy the installer tool. Even so it is a bear to get all the way in. Be sure to protect the pressure switch on your left from wayward hammer blows!
lgibson is offline
post #3 of 6 Old 2 Weeks Ago
Multiple v10tdi owner
Blownvette's Avatar
Second Vehicle: 2004 V10 TDI
07Z 198 389
This is the o-rings that need to be replaced.
Blownvette is offline
post #4 of 6 Old 2 Weeks Ago Thread Starter
Yes sir its the BKW. Im pretty confident the oil filter housing is not the culprit due to the large pool of oil sitting under the alternator. If it was leaking I dont see how it could go over that metal divider. It would just bleed around the side of the oil filter housing and down the front of the block. Here is a excellent drawing of what im 90% sure is happening lol. But I've replaced the banjo bolt and and crush washers to both of those turbo feed lines and a new oil pressure switch so I've all but eliminated those as the source. I suppose the only other culprit could be where the oil cooler is located on the oil filter housing just under where the oil filler neck is. Ive replaced the rubber gasket on the filler neck also. Do you know the part # for that seal installation tool or what it even looks like? I dont have a repair manual readily available to me.
post #5 of 6 Old 2 Weeks Ago
Blownvette's Avatar
Go to the dealer with the part number I gave you and ask for a picture
post #6 of 6 Old 2 Weeks Ago
T 10208A on the tool
Make sure itís not the oil cooler first.
lgibson is offline
