No communication with ODB reader - Club Touareg Forums
post #1 of 9 Old 03-30-2019 Thread Starter
My 2004 4.2 decided to npt communicate with my ODB/CAN reader.
I have used it with this car before.
The battery recently went dead, and wondering if there is something I should be looking for (Common blown fuses, etc.)?
N_Jay is offline
post #2 of 9 Old 03-31-2019
I had this problem with another car when one of the pins inside the vehicle connector pushed out of the plug. Your problem may be something else but good to know this can happen.
voortreger is offline
post #3 of 9 Old 03-31-2019 Thread Starter
I'll look.
N_Jay is offline
post #4 of 9 Old 03-31-2019 Thread Starter
The way the socket is designed you can't see the pins.
Still no luck.
N_Jay is offline
post #5 of 9 Old 04-01-2019 Thread Starter
Checked the pins and wires.
Anyone have any other ideas what it might be. (Has only factory accessories and radio.)
Anyone have a wiring diagram as to where I can pick up the OBD signals and jump in a socket?]
N_Jay is offline
post #6 of 9 Old 04-01-2019
Plug it into another VW/Audi if possible. Does it work?
nickyt is online now
post #7 of 9 Old 04-02-2019 Thread Starter
I have 2 readers. Both have worked with this car in the past, and both still work with my other German (CAN based) cars.
Neither one works with the Touareg right now.
N_Jay is offline
post #8 of 9 Old 04-03-2019
That makes it appear the failure is in the Touareg.
https://components101.com/connectors/obd2
post #9 of 9 Old 04-03-2019 Thread Starter
Yes, I kind of figured that part out.
Was hoping to get some hints from others that might have had a similar problem before I have to start dissecting the car.
One person on a FB group mentioned a similar problem with a bad dash cluster on a Golf.
Since that was the last thing changed (Although it appears to be working fine) I may pull it and see if the issue goes away.
One other suggestion was a bad ABS controller was a cause of a similar problem. (That is probably going to be my second thing to try)
I have asked on the VAG-COM group if it is possible VAG-COM could read past the error and give info on which modules are and are not communicating.
So far no definitive answer.
N_Jay is offline
Multiple communication codes Stuck in 3rd gear ptmichael General Maintenance & Repair 7 01-30-2019 06:25 AM
OBD reader - Suggestions for best one malefevere1 General Maintenance & Repair 13 02-07-2016 09:44 AM
"Automatic" Code Reader / Phone Link ameoba General Maintenance & Repair 1 02-26-2014 12:58 PM
No Communication with ABS Byronfuselier VAG-COM 2 04-27-2012 08:06 PM
RNS510 Sd card reader problem?? brucesailor Mobile Electronics and In Car Entertainment 9 01-26-2012 01:22 PM
