Kessy Problem? Vehicle Shutoff While Driving - Club Touareg Forums
post #1 of 26 Old 12-11-2018 Thread Starter
Hey guys/gals, this past weekend something very weird happened to me. I was driving home to the wifey Saturday evening. While at 60mph on the back roads, all of a sudden my engine shut off. No, there was no noise, no smell of antifreeze, no oil loss, just dead. I was able to pull over safely and so I started to investigate. One thing that was odd- key in the ignition but the gauges weren't activating (coming alive.) My first thought was something to do with the Kessy and Immo. Regardless, I still check the antifreeze (all there and no leaks) and also the oil (oil on stick and no sizzle when put on exhaust i.e. no blown head gasket.)
So at this point, it's time for a roll back call. I get it towed to my father-in-law's shop. After getting it in, the first thing I do is grab my laptop and run an ODIS scan. NOTHING! No comms with any module in the car. So this had me scratching my head (I'm still scratching my head a little.)
With it being late, I left it there to deal with it the next day. I go back and start looking and nothing is obvious. I keep a tool box in the Treg since I've owned it, NEVER LEAVE HOME WITHOUT IT! The next thing I check is to see if the engine seized, not that I really expected it anyway. I rotated the crank pulley and all is good. This led me to an electrical problem.
One thing I did notice the day it quit and the previous day driving, I thought I had smelled antifreeze. I know I had a slight leak during extreme cold weather around the alternator pipes. That's not what I smelled though, it was electrical but it didn't have that typical electrical burning smell.
The first thing I did was remove the battery ground strap in an attempt to reset the system to see if I could connect with ODIS or VCDS, no dice and now the key was stuck in the ignition- all fingers pointing to immo/kessy unit. Next I got on elsa and pulled up relay/fuse descriptions. All relays and fuses checked good in the plenum (engine bay) fuse box. Next I checked the SB (drivers side) fuse panel. Low and behold I have two blown fuses. SB26 & SB41. SB26 10a (Airbag control module, Motronic Engine Control Module (ECM), instrument cluster, brake/clutch switches, ESP, Mass Air Flow (MAF) Sensor.) SB41 15a (Access/start control module) Kessy. So now I'm on to something.
Next I look at wiring diagrams for the Kessy Access/start. I notice there are 2 relays one in the plenum chamber (engine bay) C20 - -J682- Power Supply Relay (terminal 50), and one under the dash D5 - -J329- Voltage Supply Terminal 15 (B+) Relay. I figure since I had the smell coming from inside the cabin that I can rule out the C20 relay in the engine bay. So now I'm looking at the voltage supply relay and the kessy. I obviously have a short going on.
I decide to put a higher amp fuse in the the dr side fuse panel on both positions 26 & 41. I go to a 20a on 26 and a 15a on 41. Key on engine off, I get gauges alive but then those fuses blow. Next I decide to go up again in amperage. 30a on 26 and eventually get to 30a on 41- I know, I know, you shouldn't do this as it risks starting a fire or seriously damaging electrical equipment. I did this because whatever is causing it, I wanted it to burn so I could identify the issue and repair it. With both 30a fuses in place they don't blow, however the ignition comes on for just a brief second, the mfi/gauges come alive for a second, flashes a couple times then off.
Next thing I decide to do is swap the voltage supply relay with another underneath the dash just to eliminate the relay giving the problem, no change so I ruled out the relay. So that led me to the Kessy unit.
I've read about the Kessy rebuilds of replacing the 2 mosfets and 6 .22ohm resistors. Here's where I run into a problem. My Kessy unit DOES NOT have the 2 mosfets and 6 .220hm resistors on this board. See my attached pictures. I did notice that there is an Infineon HITFET transistor that looks like the legs are burned at the solder/board junctions.
Has anyone else with this particular Kessy unit had/have the same thing happen to them? Were you able to repair it? Has anyone replaced this chip and the Kessy work? Since it's obviously toast at this point I figure I can't damage it anymore so I ordered some new chips to replace these. Only 2 were not available. I also felt the board after turning the ignition on and noticed the heat coming from that chip that's what leads me to believe that this is the issue. Does anyone else think there is another issue going on to check? The other reason I feel that it's Kessy related is the common battery drain I've been experiencing leading up to the engine power loss. Any insight/experiences with the same problem is appreciated.
This is my daily driver and only car so it is imperative that I get it fixed. Also has anyone copied the 93c86 eeprom and copied it to a virgin chip and soldered it to a used Kessy, install it and it work? That might be another option I explore if the chip replacements doesn't fix it. I do have my SKC from my ECU.
I am very sorry for the long winded post but I don't want to leave out any details. Still to this point, I am unable to do a VCDS/ODIS scan on the vehicle.
ID:	219673   Click image for larger version
ID:	219677   Click image for larger version
pilot60378 is offline
post #2 of 26 Old 12-11-2018 Thread Starter
I forgot to add that this is a 2004 Touareg V8 4.2l. Here's images of the entire kessy board front and back.
ID:	219681   Click image for larger version
post #3 of 26 Old 12-11-2018
Touaregman33's Avatar
The initial breaking down doesnít scream KESSY to me. To me It says more fuel pump. In my Cayenne when I had to replace the fuel pumps a similar thing happened it just shut off when driving no signs or codes. ( I didnít have a KESSY for the Cayenne)
The key being locked in the ignition definitely does now suggest KESSY, what I would do is buy a new one if itís the KESSY, you donít want to have to repair it again and have this happen again. Youíll have to put in your vin number in one of the sights and get the exact part number. Try unplugging youíre battery over night and letting it sit, then the next morning reconnect, if itís the Kessy itll start right up...
Touaregman33 is offline
post #4 of 26 Old 12-11-2018 Thread Starter
Thanks Touaregman33 for the suggestions. It definitely isn't a fuel pump problem as the fuel rail is energized and you can physically hear the pump activate when the door opens. Buying a new Kessy isn't really in the budget at the moment, however it IS last resort. I also tried disconnecting the battery, draining the system of residual and letting it sit. That didn't work as I hoped that it would.
post #5 of 26 Old 12-11-2018
If you do not have the keyless entry, you will not have those mosfets that go bad. Those mosfets are part of the keyless system and the non keyless system uses a different kessy unit. You also will not have the ability to add the start button as that circuit is only available on the keyless kessy.
It does seem that you narrowed it down to electrical with all indications being the defective part on the board. I see no different options. Replace the defective part on the circuit board and hope for the best.
If that does not work, then replacing the kessy is the next step. As far as I can tell, this is a rare isolated problem. Most of the kessy problems are on the keyless units.
Since you mentioned this. If you can copy the eeprom from your old unit to another used or new kessy, it should work without any more work needed to be done.
Good luck and keep us updated.
post #6 of 26 Old 12-11-2018
Wonít he need to code the new Kessy to interact with the Key and immobilizer?
Kessys are stupid and out of whack expensive. I understand it controls the keyless access but it shouldnít take the whole car down with it lol
post #7 of 26 Old 12-11-2018
Not if he copies the eeprom from the old kessy (which is already married to the immobilizer) to the new kessy.
post #8 of 26 Old 12-11-2018 Thread Starter
Hey Nicky, I'm confused about my t1 not having keyless entry. I have a fob, that I programmed in the system a couple years ago and it has all of the buttons on it. Unlock/lock, tailgate and panic. What is the difference between the two? I assumed I had keyless entry.
post #9 of 26 Old 12-11-2018
The keyless entry has the little black buttons on the outside door handle. You keep the key in your pocket and touch the door handle, wait 1/2 second, and the door unlocks.
When you get out, you press the little black button on the outside of the door handle and the door locks.
It can be paired with the start button. Then you can do everything with the key in your pocket the entire time.
All come with the remote key, but only some had the keyless entry.
post #10 of 26 Old 12-11-2018 Thread Starter
Ok, got ya. Thanks for clearing that up for me. As they say, make an assumption, make an ass out of yourself haha
