Intake Manifold Flap - Code - Club Touareg Forums
post #1 of 5 Old 4 Weeks Ago Thread Starter
Dear Club,
Can anyone help, I got the below error, and cleared it with my VagCom, where is the location of the manifold flap? Is there any quick fix?
Thanks in advance for your help and wisdom.
Joe
VIN: WVGPT77L16D055679 Mileage: 119160km-74042miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 906 016 CQ HW: 028 101 196 2
Component: V10 5,0L EDCG000AGM™8472
Revision: --H02--- Serial number: VWZ3Z0E6407718
Coding: 0060575
Shop #: WSC 31414 000 00000
VCID: 61C95C01BB1CDA42B2-5122
1 Fault Found:
012547 - Motor for Intake Manifold Flap (V157)
P3103 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 119141 km
Time Indication: 0
Freeze Frame:
RPM: 693 /min
Speed: 0.0 km/h
Load: 8.2 %
Voltage: 11.78 V
Bin. Bits: 00001000
Torque: 339.7 Nm
Torque: 126.4 Nm
Readiness: 1 1 0 0 0
jsantos58 is offline
post #2 of 5 Old 4 Weeks Ago
Surprisingly, it's on the intake manifold. And if your next question will be: "But where's the intake manifold?", then I suggest you just take your car to a shop to have it fixed.
The not so quick (but easily DIY-able) fix is to take off the flap, and try to clean it (because it usually has a lot of carbon/oil buildup), and see whether that makes the error go away, or if that doesn't help, then replace it.
Here's the "intake flap", which is also known as "anti shudder valve" or "shut-off flap" in diesel engines (and which - to confuse matters even more - is called "controller lid" by the parts database) in action. Behind it you can also see the EGR valve, which however you most likely won't have on a 2006 model:
Gnits is online now
post #3 of 5 Old 4 Weeks Ago Thread Starter
Thx. I did take off the cover and I saw what looked like 2 motorized housings attached to the left and right manifolds. I checked the wire harnesses and tapped the housings in case something was a little stuck. In my fault I canít figure if it is the left or right that is having problems
post #4 of 5 Old 4 Weeks Ago
Originally Posted by jsantos58 View Post
Thx. I did take off the cover and I saw what looked like 2 motorized housings attached to the left and right manifolds. I checked the wire harnesses and tapped the housings in case something was a little stuck. In my fault I can’t figure if it is the left or right that is having problems
It says V157, so, that's Bank 1. Which means the right side of the engine. Left side, when you're facing it from the front with the hood open.
That said, because both flaps are presumably of the same age and in the same condition, I suggest you also take off the one from the other side, and give it a thorough cleaning (after the first one), because that just might be not so much away either from throwing a code, if it's all carboned up.
Of course it's possible that it's the electrical part of the flap that's shot, in which case cleaning the mechanical part will not fix the issue. It's still worth a try though.
Gnits is online now
post #5 of 5 Old 4 Weeks Ago Thread Starter
Thanks for the reply and suggestions
V8 FSI Intake Manifold Flap Guides mtnride Engine, Transmission and Exhaust 20 11-19-2018 09:48 PM
Dieselgeek fix for P2015 Intake Manifold Swirl Flap error code Crowboy Australia & New Zealand 7 05-28-2017 09:27 PM
Intake flap stuck - now fixed itself buckwheat Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 0 12-02-2016 04:00 PM
Vagcom not talking to me!! krankybuluk VAG-COM 11 08-26-2012 01:21 PM
Intake manifold flap position sensor issue nickm General Maintenance & Repair 36 06-03-2012 06:46 PM
