HVAC Service position - Club Touareg Forums
post #1 of 3 Old 06-03-2019 Thread Starter
Hi all,
I've got to remove the dashboard soon to take a look at the actuators as i've only got cold air on the passenger side and i've read the instructions on the forum and it says to put the HVAC into service postion before you start so is this to put the actuator spindles in the correct position so that you can put them back on easier ? The reason i ask is that i don't have full VAGCOM and i've done the same job on a previous car i had (Jeep Grand Cherokee) and just found i had to manually spin the motor until it was in the correct position.
I know someone with the full VAGCOM but i'm not sure when i'm going to get around to it so though if it IS just a case of it putting the motor in the correct position then i could do the same manual thing i did on the Jeep ?
Hope this makes sense.
TouregNewbie is offline
post #2 of 3 Old 06-04-2019
Service position puts the flaps in a position, so that they and their actuators can be safely removed from their place. The area is very restricted, so, you might or might not be able to do anything "manually" with them.
You'll also need VAG-COM after the repair to reset the basic settings for the temperature flaps and recalibrate the A/C. If you don't do that, you might still not get proper air mixing, despite having replaced the flap motor with a good one.
Gnits is online now
post #3 of 3 Old 06-04-2019 Thread Starter
aaah, yes, that makes sense.
Many thanks, think i'll get it in position either way.
