Horn stopped working - Club Touareg Forums
post #1 of 14 Old 03-31-2019 Thread Starter
Hi, today my horn stopped working. I have a 2008 Touareg 3.0 TDI. I checked the fuses which looked okay, although I am not sure I checked the right ones. Anyone got a fuse schematic for this model? I have also read it could be a problem with the horn itself, apparently taking off the front bumper and spraying some WD40 up the horn and waiting a day before laying on it again is a possible fix. Another possibility is the ground and connecting wires from the battery have come lose. Am I missing something here? My access to good tools to remove the front bumper is somewhat limited. I’m really hoping its just a fuse but I dont know which one.
Albania/Kosovo
drewbreezy is offline
post #2 of 14 Old 03-31-2019
Use a meter to see if you're getting signal to the horn... if not, start looking at fuses and wiring.
If you do get a signal, then the WD-40 approach can be entertained.
post #3 of 14 Old 03-31-2019 Thread Starter
I have one of those screwdrivers that lights up if i touch something to show signal. I assume I would need to take off the front bumper and find the wires from the battery to the horn to test this?
Albania/Kosovo
post #4 of 14 Old 03-31-2019
Before you do anything else try the WD40 fix. It costs nothing!
post #5 of 14 Old 03-31-2019 Thread Starter
Okay, just not sure how to get to the horn exactly.
Albania/Kosovo
post #6 of 14 Old 03-31-2019
Do you know what the horn looks like?
Do you know what are you should be looking in for it?
Do you understand what it would take for the horn to function?
You need some basic knowledge before you can fix something.
post #7 of 14 Old 03-31-2019
2005-2010 Volkswagen Touareg Fuse Box Diagram » Fuse Diagram
post #8 of 14 Old 04-01-2019 Thread Starter
Sweet, thank you. Now I can’t seem to find the one that reads horn.
Albania/Kosovo
post #9 of 14 Old 04-01-2019 Thread Starter
I do know what it looks like. I also know I have to take off the front bumper to get to it. I do not know however the engineering mechanics of how a horn works. I was hoping to spray some WD40 up in the trumpet and hope for the best.
Albania/Kosovo
post #10 of 14 Old 04-01-2019
For one, there are actually two horns: a high and a low pitched one. If you've no horn at all, that means that the second one has also failed.
The horns are known to die after a while. So, even though of course check fuses and such, but it will be most likely the actual horn that has died on you. You can try to get it back to life with WD40, but don't get up your hopes up on that.
You also can't take the horn apart without destroying the housing - so, even if you would be able to repair it by taking it apart, it will most likely die on you in a short time afterwards, because of the housing not sealing properly anymore.
The workshop manual says to remove the bumper first to replace the horns, but you can replace them without that (thanks to the holder arms), if you have small enough tools and hands.
Gnits is offline
Horn not working Sibley83 General Maintenance & Repair 1 02-02-2019 11:06 AM
2012 Touareg horn stop working supersbk General Maintenance & Repair 0 02-29-2016 10:21 PM
2006 heater blower motor stopped working jsammons USA - Central 11 02-17-2016 08:06 PM
Nav Stopped Working, Then Radomly Started Stoiclown Mobile Electronics and In Car Entertainment 0 07-16-2012 10:36 AM
Horn not working on Touareg 2004 TDI MouskiPE General Maintenance & Repair 2 08-02-2009 02:02 PM
