HELP!! Touareg 2.5 - Club Touareg Forums
post #1 of 2 Old 04-10-2019 Thread Starter
Touareg: 2005 R5 TDI
Second Vehicle: Old heap
Unhappy HELP!! Touareg 2.5
Hello, what can it be? thank you
Part No SW: 3D0 909 135 N HW: 5WK 470 21
Component: Kessy 6610
Revision: 66105312 Serial number: VWZ3Z0D1277420
Coding: 0000234
Shop #: WSC 31414 000 00000
VCID: 306FF64BA0D6889E243-5072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0000230
VCID: 3561C75F5FB4ADB6775-5000
2 Faults Found:
00353 - Function Return Message from Fresh Air Blower Regulator
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Voltage: 14.20 V
Voltage: 10.31 V
Voltage: 8.15 V
Voltage: 14.00 V
010 - Open or Short to Plus
Freeze Frame:
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 M
Component: 3001
Coding: 0065660
VCID: 4683B0933252362EEEF-5000
6 Faults Found:
00968 - Right Turn Signals
014 - Defective - Intermittent
01498 - Bulb for Parking Lamps; Right (M3)
010 - Open or Short to Plus - Intermittent
00979 - Lamp for Low Beam; Right (M31)
000 - - - Intermittent
01800 - Light Switch (E1)
01520 - Rain and Light Recognition Sensor (G397)
Part No: 7L0 959 933 E
Component: GB HSG 0201
Coding: 0000065
Shop #: WSC 55215 001 1048576
VCID: 3E73D8736A826EEEA6F-4A3A
Subsystem 1 - Part No: 7L0 959 701 G
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 G
Component: Tuersteuergeraet BF 0202
Subsystem 3 - Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 C
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0020
Subsystem 6 - Part No: 7L6 951 171
Component: A Innenraumsensor 0019
7 Faults Found:
00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent
01516 - Terminal 30; Left
00926 - Terminal 30
00668 - Supply Voltage Terminal 30
00987 - Lamp for Brake Light; Left (M9)
009 - Open or Short to Ground - Intermittent
00108 - Signal Central Locking SAVE/LOCK Rear Right
00931 - Locking Module for Central Locking; Rear Right (F223)
Alessandro Oldani is offline
post #2 of 2 Old 04-10-2019 Thread Starter
plus I do not work the cruise control, I changed the button on the brake pedal to be scrupulous but it does not work the same, the warning light turns on but when I press the keys it does not keep the speed
Replacing alternator on my 2004 2.5 touareg. Frazer44 Europe 3 12-18-2015 09:29 AM
Want to Buy: TDI 2.5 Touareg Engine 2004 model. Ravers Classifieds 0 06-22-2012 01:25 AM
Touareg 2.5 R5 TDI or 3.2 V6 Tiptronic mhlebec3 New Member Introductions 4 04-08-2012 11:00 AM
