Heater fan won't shut off - Page 2 - Club Touareg Forums
post #11 of 24 Old 02-14-2019 Thread Starter
Yes, looking at the schematic, looks exactly like bitron, G462 is sending the ground to the heater motor, so might have gone bad, and that explains why motor runs with key off and removed. This is the only place the motor would receive power, the positive side is connected always and the ground is switched on or off from a signal the bitron is receiving from the control unit, or in this case even not getting a signal, it is still grounded because???the bitron is shorted out??
Russell Parker is offline
post #12 of 24 Old 02-14-2019
Touareg: 2008 V6
The Bitron sounds like the culprit to me then. Bitron replacement first, fan second. Does anybody know what the voltages should be?
wesbronco75 is offline
post #13 of 24 Old 02-14-2019
It looks like the large spade lugs (which modulate the power to the fan) inside the bitron shorted. It will be interesting to see if the same thing happened to both of you. If you replace the bitron and fix the problem, please check the old bitron and let us know.
wesbronco75 (02-21-2019)
post #14 of 24 Old 02-21-2019
Touareg: 2008 V6
Bitron was the culprit for me, fan seems to be fine for now. Does anyone have any suggestions for replacing the plug on the wiring harness? My wires are melted too.
ID:	221173   Click image for larger version
post #15 of 24 Old 02-21-2019
Touareg: 2008 V6
Bitron was the culprit for me. My end connector on the wiring harness melted too, does anyone know where to get a replacement clip?
ID:	221179   Click image for larger version
post #16 of 24 Old 02-21-2019
4ePikanini's Avatar
Touareg: 2005 R5 TDI
Jip. Just had the same.
New bitron on the way. I also requested a piece of the harnass from the breaker.
2001 Gen3 Di-D LWB - SOLD
4ePikanini is offline
post #17 of 24 Old 02-21-2019
4ePikanini's Avatar
There is a cutaway at the back of the cubby hole. Very easy access to it.
Just prod around with your nail, you will find the perforation lines.
post #18 of 24 Old 02-22-2019
Touareg: 2008 V6
4ePikanini, Do you have a part number for that piece of wiring harness? Who did you order from?
post #19 of 24 Old 02-22-2019
Touareg: 2008 V6
After taking some clearer photos of the connector, I found the part number 1J0972752. I think I have lots of options now. I'm going to strip the insulation back and see how far that corrosion goes.
post #20 of 24 Old 02-22-2019
Thanks to the part number, there are all sorts of options. Good work guys.
www.google.com/search?q=1J0972752
T3 auxiliary heater locked out Scubacruiser General Maintenance & Repair 34 02-12-2019 03:01 PM
2015 Canadian Touareg 7P Webasto parking heater retrofit chewblekka Touareg DIY and Technical Info - DO NOT POST NEW THREADS ASKING QUESTIONS 77 02-12-2019 07:16 AM
T2 reducing agent heater bypass MIL P202A almstsobur Engine, Transmission and Exhaust 1 06-30-2016 09:18 AM
Compressor Shut off for condenser fan ChuckWay General Maintenance & Repair 0 04-12-2012 11:01 AM
Fan speed fro heater is not consistent jcarto General Maintenance & Repair 0 01-26-2012 06:59 AM
