Headlight right side not working - Club Touareg Forums
post #1 of 3 Old 02-25-2019 Thread Starter
Good evening everyone... and anyone that might assist. Both low beam and high beam are out on passenger side, mechanic told me to buy a whole assembly for my 2004 Touareg. Enter LKQ for reputable parts, still Not working, checked fuses, all good, is there a relay or other area to check? Free advice from VW service dept said I might buy a new control computer for a few hundered or jiggle the electrical harness that plugs into the back of the housing. And make sure the headlamp housing is locked in completely.
Lukedupre2019 is offline
post #2 of 3 Old 02-25-2019
Since all lights in that headlamp assembly are out the first suspect would be the connector the headlamp assembly slides into. Slide the headlight out and use a flashlight to make sure the connector the headlamp slides into is properly located. (check the other side if you wonder what it should look like.) Also take a look at the wires at the connector to see if any are broken or appear to be loose. You MAY be able to wiggle the connector around to the point where it makes a good connection.
If the plastic that holds the connector in place is broken or cracked it is a HUGE PITA to replace!
Fourdiesel is offline
post #3 of 3 Old 02-25-2019 Thread Starter
Thank you, that looks fine, maybe my godfather missed a fuse or relay, do you know which ones to check or where the power source wires are that would lead to the passenger headlamp?
Adaptive Cruise Control and Side assist not working Johnnytruelove New Member Introductions 4 01-17-2016 04:59 PM
Side mirros not working paulo8 General Maintenance & Repair 7 09-17-2014 07:46 AM
Passenger side headlight out LShep General Maintenance & Repair 1 05-30-2011 06:35 PM
For Sale: WTB Driver's side fender and Xenon Headlight grateful_carl Classifieds 0 12-09-2010 12:20 PM
ACCESSING THE PASSENGER SIDE HEADLIGHT (BULB REPLACEMENT) no03330 General Maintenance & Repair 0 07-13-2007 06:28 PM
