Headlight out. - Club Touareg Forums
post #1 of 8 Old 3 Weeks Ago Thread Starter
Headlight out.
So my headlight isn’t working. I’ve replaced the bulb twice. All the other bulbs work in the casing. The high beam, the little yellow one etc. Could it be a fuse? Or is the whole housing bad? But if the housing was bad the others wouldn’t work correct?
gxavier6 is offline
post #2 of 8 Old 3 Weeks Ago
On what?
post #3 of 8 Old 3 Weeks Ago
On what indeed!
Click on User CP to update your profile with your model, year and location.
You will need to click out of the mobile version of this site if using your phone or use a PC to see the User CP "button".
This helps people help you.
post #4 of 8 Old 3 Weeks Ago
I think he wants us to guess.
My guess is .... on a snowblower
post #5 of 8 Old 3 Weeks Ago Thread Starter
Sorry I still don’t know how to use this forum. I have a 2007 Touareg. My headlight and high beam not working. Only the little yellow light on the end. Could it Be the whole headlight housing or a fuse ?
gxavier6 is offline
post #6 of 8 Old 3 Weeks Ago
Ok. 2007 Touareg. Don't know if it is the halogen or the HID, but we can skip that for now.
You could have something as simple as a fuse. Need to check those first.
You could have a bad bulb. The troubleshooting will depend on if you have halogen or HID headlights.
The headlights are known for going bad. For some reason the insulation will literally fall off of the wires that are located and sealed inside the headlight. For the most part, the only solution to that is a new headlight.
There is a small wire harness that costs about $50 that hooks directly to to back of the light in the T1. Your 2007 is probably a T2, but that is a crossover year. That T1 small wiring harness also goes bad a lot.
If the bottom of the headlight is flat, it is a T1. If the bottom of the headlight has a teardrop shape, it is a T2.
See how quickly things get complicated.
nickyt is online now
post #7 of 8 Old 1 Week Ago Thread Starter
Thanks everyone. Turns out I was checking the wrong fuse. It was indeed a fuse.
gxavier6 is offline
post #8 of 8 Old 1 Week Ago
Please click on User CP and update your profile as previously requested. This helps others help you.
Left headlight, parking light, turn signal not working HIRacing General Maintenance & Repair 14 07-30-2018 09:35 AM
Headlight Mod, Painting the inside and Projector lens swap johnsc2 Touareg Exterior Mods 19 11-26-2017 10:35 AM
Headlight Release Bolt Broken Laki22 General Maintenance & Repair 11 04-28-2015 08:41 AM
Headlight assembly OneLeggedMAN125 General Maintenance & Repair 5 03-02-2012 02:14 PM
