New to this Forum and am looking to acquire a 2011 Volkswagen Touareg V6 TDI 7P Auto 4XMOTION MY12.... my question relates to connecting in an Anderson Plug wiring with the electrical system. Since these vehicles have a smart alternator, as I understand it. its lees than desirable to connect direct to the battery terminal. The info I have indicates that the battery terminal has a sensor that allows the ECU to charge the battery and when charged control the charging voltage/current for the vehicle systems load and that it where I understand the termination should be made for the Anderson Plug. Since the battery is well hidden under the seat I think the direct battery feed terminal is located in the LH side of the engine bay. If that is correct which particular termination should I connect it to.
Goodmonkey thanks for your reply
firstly I hail from Eatons Hill in QLD the Anderson Plug is for a caravan so I am looking at 30 Amps absolute max for an initial surge if the battery is very low + the van is equipped with a 3 way DC to DC fridge so that is around the 10 Amp continuous the DC to Dc charger is only a 25 amp.
My back ground is as an Avionics Maint Engnr so am comfortable doing the work.
Thanks again
Why not use a normal caravan connector plug/socket - in Europe we now use a single 13-pin plug/socket which has fridge and permanent battery supply both rated at 25 amps - oversized cables in car and caravan will reduce voltage drop to a minimum.
My 2014 had a spare fusible link under the hood which connects to the battery. I used an XT90S connector since it's smaller, has anti-spark precharge, and rated 90A.
I also installed an XT90S in the trunk, using a flip top cigarette lighter housing to integrate it into the interior panel. I ran 8 awg wire to the battery, there was a spare 60A midi fusible link there too, I added a 30A maxi fuse.. You can feed a fish tape from the trunk to the battery without taking much of the interior apart.
