CABLE FOR SMARTHPHONE OR TOMTOM - Club Touareg Forums
post #1 of 12 Old 04-26-2019 Thread Starter
Hi all,
I would like to install a cable to charge my tomtom or smartphone. I have a 2015 Touareg r line.
Do you have any suggestion?
I was thinking to connect to the cigarette lighter as I have done with my Touran.
But I am having difficulties to understand how to open the center console.
I do not like flying cables and I do not like the tomtom charger always in. This does not allow me to close the ashtray cover. Not a serious problem but do not understand why even new cars do not offer a solution to this. A little door on the dash with ports will work perfectly. I have seen diy solutions but not happy to cut a hole in my dashboard.
Thanks,
F
Francesco Mosca is offline
post #2 of 12 Old 04-26-2019
WTF..... didn't you get the OEM RNS with Nav? What do you need TomTom for?
post #3 of 12 Old 04-26-2019 Thread Starter
The oem satnav is rubbish for me. Tomtom and google maps much superior.
post #4 of 12 Old 04-26-2019
So wire it into your side fusebox and have it on your side of the dash in the corner.... no cords all over or anything.
post #5 of 12 Old 04-26-2019 Thread Starter
Thanks. Where is the nearest fusebox and how I make the connection? I have a RHD car.
post #6 of 12 Old 04-26-2019
There's one on each side of the dash
http://fotohostingtv.ru/out.php/t175...ru12084608.jpg
post #7 of 12 Old 04-29-2019 Thread Starter
Thank you.
The fuse box looks great, there is a lot of space behind the cover.
1) What fuse should I use? VW does not provide a fuse chart. I need one that is live when the car is on. I can check this with a tester. Ideally the cigarette lighter one but how can I identify it?
2) one cable will go in the fuse and the other in the metal behind the fuse? I suppose It will be a live negative? I can check this with my tester I suppose.
F
post #8 of 12 Old 04-29-2019
Find something that only works when the key is on.... either by reading whatever manuals you have, or testing, etc.....
Then use a "add a fuse" kit to piggyback onto that..... simple
https://www.blackboxmycar.com/pages/...add-a-fuse-kit
You can always google "using a multimeter" and such if you're struggling with testing for keyed power sources.
post #9 of 12 Old 04-29-2019
post #10 of 12 Old 04-30-2019 Thread Starter
I have been able to identify the cigarette lighter fuse. number 38 in the above video.
I think the fuse size is a standard ATO (about 2cm x 2cm x0.5 cm)
I will get a fuse tap like the one below link and I should be able to do my connections and easily pass the cable behind the dashboard.
https://www.ebay.co.uk/itm/Add-A-Cir...53.m1438.l2649
I will first attach my TOMTOM charger. I cannot find on the Internet which one is the positive on the charger, so the one that will connect to the fuse box.
I suppose the tip is the positive and the sides are the negative?
I will probably use some electric tape for the connections. Not elegant but nobody will see it and it will be temporarily only.
In future I will attach a usb cigarette lighter adaptor for my smartphone. Anyway about the same. I believe they are all 5Volts.
Still I do not understand why manufacturers do not provide loads of USB ports in the cars. Some new cars have a few must admit but not all and not on the dash.
F
Broken Bonnet / Hood Release Mechanism Okete General Maintenance & Repair 6 09-15-2016 09:07 AM
Adjust Park brake cable dragline1570 Brakes, Steering, Suspension, Wheels and Tires 9 08-03-2014 07:00 AM
Park Brake Cable Replacement scottimac General Maintenance & Repair 0 07-09-2014 11:56 PM
9W7 Bluetooth Upgrade - Troubles Routing New Cable with Stereo danoberg7 Mobile Electronics and In Car Entertainment 5 11-29-2012 11:35 AM
