Brembo Brake Pad Pins Stuck? - Club Touareg Forums
post #1 of 9 Old 08-04-2011 Thread Starter
red.king's Avatar
Touareg: 2006 V6
Question Brembo Brake Pad Pins Stuck?
Hi All,
I am trying to change the pads on rotors on my Treg. I cannot for love nor money get the pins out?
I have cleaned and then lubed with WD40, belted with a hammer and punch but absolutley no joy whatsoever.
Any tips or advice?
red.king is offline
post #2 of 9 Old 08-04-2011
Official CT Ricer!
catalystgod's Avatar
All those chips/dents on the caliper....are those from you hammering on the pins?
Also, try PB Blaster, not WD40.
catalystgod is offline
post #3 of 9 Old 08-04-2011
BigMM24's Avatar
keep trying? i too had hammer and punch in hand... larger punch at first then smaller to fit in the hole. it did take a bit. when you get them out, use a wire wheel brush to clean em up.
edit: and as far as i recall, hit it from the outside in, its a one way system (looks like you've attempted at both sides)
13 Triumph D675r ~3kmi
06 5.0l Touareg TDI ~115kmi
02 1.9l Golf TDI ~190kmi
00 4.0l Jeep Wrangler ~155kmi
01 2.0l Jetta ~160kmi (sold)
08 Yamaha R6 (totaled)
Drive more. Worry less ~VW
BigMM24 is offline
post #4 of 9 Old 08-04-2011
ameoba's Avatar
Second Vehicle: 2008 V6
It looks like you hammered on both sides....? I see marks in the first picture on both sides of the calipers.
Those pins should literally slide out with a small tap. I'm guessing you have somehow jammed them in there. One thing I would recommend is finding a different punch. It looks like you are using some sort of tapered punch with a small head on it. Find something with a broader head that will transfer the energy better. I ended up using a much larger punch and the front pins (2 on each side) came out easy. The rear pin (1 on each side) was a total PITA.
Current:
Gone to a great new home:
ameoba is offline
post #5 of 9 Old 08-04-2011 Thread Starter
red.king's Avatar
Touareg: 2006 V6
Got them out! There was evidence of glue of some sort on the pins???
Yes, I did also tap from the inside-out, however that was just a few light taps to try and break the bonding point at that side.
Also, I used various sized punches, from small to large, but no budging at all.
The solution:
1. Ample amounts of WD40 (to be cleaned up before new pads and rotor goes on).
2. After soakage, lightly tap the inside of the pins (ref above point about bonding point).
3. Using a vice-grips, grip the pin and then tap the vice-grips with a hammer. I was afraid of bending the pins and adding more dents on the caliper housing by tapping from the outside in.
Why the hell would someone glue those suckers in place?? According to the service log it was my local VW dealer who last changed the front rotors.
Once the glue bond broke both pins came out easily
Thanks all for the advice and help!
Red.
red.king is offline
post #6 of 9 Old 08-04-2011
Official CT Ricer!
Glue! WTH! I guess somebody was at the dealership!
post #7 of 9 Old 08-04-2011
V10
V10's Avatar
I use anti-seize grease on them to prevent corrosion which will act like glue or even worse sometimes.
V10 is offline
post #8 of 9 Old 08-04-2011
Official CT Ricer!
That is really odd. I have used anti seize on my car several times because I work so much on it, but I have NEVER seen it do that!
post #9 of 9 Old 3 Weeks Ago
Seamus09Treg's Avatar
I am about to tackle this same problem. My 9 year old could have tapped the drivers side line out buy the passenger side is a different story.
After tapping one pin with a hammer the pointy tip crushed easily. Stopped there and ordered pins.
Got the pins today and I'll get a few pics to post of my attempt for entertainment purposes only.
Also thank you to all who've posted on this site. Bought my 09 v6 a few months ago and this place is Awesome for research.
Seamus09Treg is offline
Brake Pad Replacement - 2 pins etlmsmh New Member Introductions 3 05-05-2011 06:50 PM
07 Front pad removal V6 - Guide pins Bannonjr Brakes, Steering, Suspension, Wheels and Tires 4 05-05-2011 06:46 PM
VW Volkswagen Touareg Front Brake Pad Set OEM BREMBO eBay Watch Volkswagen Touareg Wheels, Brakes & Tires 0 04-16-2010 01:21 AM
VW Volkswagen Touareg REAR Brake Pad Set OEM BREMBO eBay Watch Volkswagen Touareg Wheels, Brakes & Tires 0 04-15-2010 10:30 PM
