battery dying - Club Touareg Forums
post #1 of 7 Old 03-20-2019 Thread Starter
battery dying
Hey guys and gals, my new to me 2004 v8 Touareg (180kmiles) is having battery issues. The PO (my stepdad) replaced the battery in March 2018. I don't drive it very often, and it regularly sits for 2-3 weeks at a time.
The Treg wouldnt start about 3 weeks ago, after sitting for about 2 weeks. I thought maybe I left a light on or something. I charged it and drove it a few hundred miles over the weekend with no problems, the parked it. A few days later i checked it and battery was completely dead (4.2 v). I realized that I accidentaly left the headlights on for 2 or 3 days!
I put the charger back on, and then ran the battery conditioning cycle on my battery charger (took about 24 hours). The Treg sat for 4 days while I was out of town. Today, the battery is down to about 4v again. I'm assuming I killed the battery with the 3 day headlight drain, but want to check all options before I replace the battery again.
I read about a problem with the battery to alt cable. I found a note from PO that the says in 2007, with 70k miles: Recall done: N5 = Air Cleaner and Alternator wiring. Is this the battery to alt cable issue that I read about? If so, would it have gone bad again? If not, how big of a job is it to fix the battery to alt wiring?
Thanks!
hpcaub is offline
post #2 of 7 Old 03-20-2019
Where is the car when you leave it?
Where are the keys when you leave it?
Is the car properly locked up each time?
Is there a mains power point you could use to plug in a battery conditioner like a Ctek?
Here's how to fit a new battery:
https://www.mytreg.com/index.php?/to...es-in-the-v10/
post #3 of 7 Old 03-20-2019 Thread Starter
hpcaub
Thanks for the battery change link, Noobytoogy. Treg is parked in my driveway, locked up, with keys in the house about 40 feet away. I'm not sure what a Ctek is, but my charger has a "conditioner" mode that I tried to use. I suspect I damaged the battery beyond repair by leaving the lights on. I'll probably hookup a trickle charger quick connect after I get a new battery, so I can keep it charged when sitting for weeks at a time.
hpcaub is offline
post #4 of 7 Old 03-20-2019
Multiple v10tdi owner
Blownvette's Avatar
Second Vehicle: 2004 V10 TDI
There is a lot of things that can cause a draw. Best to start with a known good battery and see if you have problems after a good battery is in place. From there a search on this forum can show the main places to check and explain what vcds is and how to use it for tracking down problems.
If the radio is not stock or even if it is and you are still having a drain issue you may want to pull a few fuses for the radio and see if that helps. Also make sure that the battery is the correct size. I had a car with the wrong size battery and it caused a world of issues!
Blownvette is offline
post #5 of 7 Old 03-20-2019
If you want to check for a parasitic leak:
TRespect is offline
post #6 of 7 Old 03-20-2019
TRespect is offline
post #7 of 7 Old 03-20-2019
I suspect the battery is toasted.
But if you have a second vehicle, you can remove it and take it to a parts store and have them test it for you first. But expect to buy a new one.
T3 battery replacement chassis General Maintenance & Repair 30 3 Weeks Ago 04:23 PM
T2 Battery/charging issues gldgti General Maintenance & Repair 32 12-20-2018 10:41 PM
How to replace your stock Touareg BATTERY Tahoe Touareg DIY and Technical Info - DO NOT POST NEW THREADS ASKING QUESTIONS 187 10-04-2018 12:43 AM
T3 completely flat battery overnight Toiler Australia & New Zealand 4 05-30-2015 08:10 PM
04 V8 Voltmeter bouncing, battery dying wheat04T1 General Maintenance & Repair 7 06-11-2013 08:22 AM
