AC starts off strong, loses power. - Club Touareg Forums
post #1 of 4 Old 03-12-2019 Thread Starter
My AC hasnt been used all winter. Now that spring is approaching I turned it on max to give it a test. For about ten seconds it blows cold air when all of a sudden a pretty loud humming noise comes from behind the dash and the air flow cuts to basically 0. Ive tried different speed and airflow settings with the same results. The heat still works fine. Im in the process of changing a faulty engine speed sensor, not sure if that could be part of the issue as Ive read random and strange things can happen without a functioning engine speed sensor. Any ideas?
Albania/Kosovo
drewbreezy is offline
post #2 of 4 Old 03-13-2019
If the humming is coming from the driver side or from behind the center console, then it's most likely one of your temperature flap actuator motors, that lost some cogs and is now unable to orient the flaps correctly. If it's coming from behind the glove compartment, then it's the blower itself (or the coil pack that controls its speed) that probably overheats or something.
Anyway, you should read the fault codes with a VAG-COM device, because in either case there's usually a code that will exactly tell you which component is at fault.
Gnits is offline
post #3 of 4 Old 03-13-2019 Thread Starter
The humming seems to come from behind the center dash. The weird part the problem doesnt start right away. It works perfectly for about 10-20 seconds. Speed controls on the airflow seem to work fine within the first 20 seconds before it cuts to basically no airflow. The heat and the airflow associated
with it hasnt missed a beat. The shop didnt mention anything about any other codes showing other than the engine speed sensor being broken.
Albania/Kosovo
post #4 of 4 Old 03-15-2019 Thread Starter
Speed settings change normally, as long as Im using only the heat. When I took it to the shop they didnt mention any codes showing up, but I had taken it there for a totally different issue.
Double checked again today. The humming is definitely louder from glove box area. Last summer I remember, only when it was really hot outside,sometimes the AC would make this same noise as soon as i turned it on but quickly went away and functioned normally.
Albania/Kosovo
Oil pressure and power steering connected? 2007 V10 TDi Jessica Mathews Engine, Transmission and Exhaust 2 12-09-2016 08:24 AM
Accessory power lead on a 2008 Touareg? Danielsan Mobile Electronics and In Car Entertainment 2 11-19-2016 05:16 PM
uk 2006 v10 tdi loss of power upon hot restart PBA400 General Maintenance & Repair 6 09-03-2016 05:20 AM
battery went dead no power inside treg trevor7404 General Maintenance & Repair 14 05-02-2015 03:30 PM
Do I believe J D Power? batman47 General Maintenance & Repair 14 08-30-2004 09:49 PM
