'13 TDI Faults galore - Club Touareg Forums
post #1 of 21 Old 04-14-2019 Thread Starter
Unhappy '13 TDI Faults galore
Got the Treg back from the dealership a few days ago after new pads/sensors/rotors, a new throttle inlet boot pipe, and a detail. Drove fine until today. When trying to start the car it is throwing an ECS Fault, Transmission Fault, Airbag Fault, Glow Plug Fault, and an Adaptive Lighting Fault.
Sounds like someone might have mucked something up. Maybe a wire harness or ???
I wanted to get your opinion on the matter. I'm definitely calling the dealer first thing in the morning. They kept it for four days, claiming they were waiting for the inlet boot pipe to come in the mail and that it was dangerous to drive with a small oil seep coming out of the old inlet boot pipe. I'm starting to get suspicious that they screwed something up, didn't tell me, and it took them a couple days to get it to work.
Full disclosure: Malone stage 2 software and Rawtech DPF/Cat/DEF delete. I was considering attempting a re-install of the Malone tune just for fun, but figured it probably would not have started if they had messed with the software. I told them about all this before they began work, but it's not the first time they didn't listen to me. I had a Tiguan with APR stage 1 tune that they overwrote after I explicitly told them not to.
BoilerBrad is offline
post #2 of 21 Old 04-14-2019 Thread Starter
I neglected to mention that the tachometer cut out the last time it ran and the engine seemed to be idling at higher RPMs than normal. It wont start at all now.
post #3 of 21 Old 04-15-2019
Wait, wait, wait...... so your dealer of choice already caused you headaches in the past on previous modified vehicles, but you took your current modified vehicle to them this time around too? Interesting........
With regards to all your faults, I'd definitely give it back to them to fix, and being that it's a '13, you should be covered for mostly anything under the extended emissions warranty..... but I don't know how you'll invoke that coverage given your mods and full disclosure.
Keep us posted.... many of us are weary of doing any mods for fear of this kind of situation while still under the coverage.....
post #4 of 21 Old 04-15-2019 Thread Starter
Thanks for your constructive comment
Sorry if I was misleading. I don't have a lot of choices where I live and figured loyalty is worth something. I've been taking my Volkswagens to this dealer for ten years now. They've messed up once and owned it.
I was fully aware of what I was doing when I installed the mods and wont be trying to invoke voided warranties. If you mod your car in this manner, kiss the warranty goodbye.
Not trying to rip off Volkswagen. Just want my car to work
post #5 of 21 Old 04-15-2019 Thread Starter
I just checked all the fuses in the driver and passenger side fuse panels and didn't see anything blown. Does anyone have any ideas? I did notice the panel under the glove box in the passenger foot well was loose and a screw was on the floorboard. Is there anything up in there that would be a common denominator between all the issues i'm seeing?
post #6 of 21 Old 04-15-2019
While you're scratching your head, check for a weak battery or bad battery ground. Low voltage can light up the Christmas tree.
Gary, 13 TDI, Myakka City Florida
Xcentric is offline
The Following User Says Thank You to Xcentric For This Useful Post:
BoilerBrad (04-15-2019)
post #7 of 21 Old 04-15-2019
Without a VCDS scan, I can't think of too much to add.
VW will not work on a vehicle with a tune. The best case is that they flash it back to factory and then fix it under warranty, without charging you for the free update.
Not much use asking the dealer not to flash it. VW HQ pretty much demands them to flash it.
With the way the dealer computer is now 24/7 hooked to the VW mothership, the diagnostic software might even refuse to do anything except demand a flash as step one.
Make sure the battery has a full charge and look under the hood around the air intake. Make sure that all the wiring harness appear to be connected and fully clicked together. I could see many of these codes appearing IF the dealer had unhooked a engine wiring connector, half way plugged it in, and the connector then vibrated loose.
Follow the wires from the glowplug back as far as you can. Ditto for the Air Intake.
That's all I got folks. Good Night.
nickyt is online now
post #8 of 21 Old 04-15-2019 Thread Starter
Very helpful, Thank you!
post #9 of 21 Old 04-15-2019 Thread Starter
Well, I had it towed to the dealer. They confirmed the battery is OK and told me it's a 'CAN-BUS communications problem'. However, they have no idea where the issue lies - a bad connection, broken wire, could be anything. I asked if they unplugged anything when they did the work on it last week and they assured me they did not. They also say they did the good-old tug test on everything they touched. They also said it's likely not related to the ECM. I gave them the go-ahead for a few hours of diagnostics and troubleshooting.
post #10 of 21 Old 04-15-2019
Megaboss268's Avatar
My dealer sells flashes. Not sure if they would flash a TDI but they advertise tunes there, and not just the warranty covered ones from APR.
2014 Touareg TDI LUX
yrktreg TCM flash
AutoHold retrofit
A Few VAGCOM mods
Megaboss268 is offline
Los Angeles Auto Show 2008 - Touareg TDI with Clean Diesel phaeton General Maintenance & Repair 8 02-25-2019 03:52 PM
Intro and Fault Codes Galore... slcousin General Maintenance & Repair 5 02-13-2016 10:33 PM
For Sale: 2010 VW Touareg TDI 79500, new AdBlue system, Florida car (pampered), $27k OBO eyevet Classifieds 3 10-08-2014 06:50 PM
Los Angeles Auto Show 2008 - Baja Touareg TDI phaeton General Maintenance & Repair 2 11-20-2008 07:16 AM
V6 TDI Pricing barefoot Australia & New Zealand 3 09-08-2006 02:59 AM
