08 Touareg 4.2L Laundry List of Codes - Club Touareg Forums
post #1 of 1 Old 04-24-2019 Thread Starter
08 Touareg 4.2L V8 111,000 miles
Recent repairs -
2 air filters
2 MAFs
Fuel pump (tank) gaskets
Fuel Filter VDO (driverside tank)
All brake hard plastic vacuum lines
- Car ran fine for 2 days.
- Started hard starts today, stalled when driving home.
- Could start and idle, but little to no throttle response.
- Couldn't move more than idle speed.
- Found burned terminal on fuel pump main plug.
Additional parts on order
- passengerside fuel pump (single pump system)
Any help would be appreciated.
Readiness: 0000 0000
Wednesday,24,April,2019,19:32:15:13218
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0 (x64)
Data version: 20190114 DS296.0
www.Ross-Tech.com
Address 01: Engine Labels: 079-907-560-BAR.clb
Control Module Part Number: 7L0 907 560 E HW: 7L0 907 560 E
Component and/or Version: 4.2l V8/4V 0030
Software Coding: 04210009590F0960
Work Shop Code: WSC 31414 790 00001
VCID: 336575745106CAD210-5140
10 Faults Found:
000135 - Fuel Rail/System Pressure
P0087 - 008 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 180095 km
Time Indication: 0
Date: 2019.04.20
Time: 13:44:57
Freeze Frame:
RPM: 3122 /min
Load: 100.0 %
Speed: 58.0 km/h
Temperature: 99.0�C
Temperature: 48.0�C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
008584 - Bank 1; System too Rich at Idle
P2188 - 008 - - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 180126 km
Time Indication: 0
Date: 2019.04.21
Time: 10:52:10
Freeze Frame:
RPM: 2619 /min
Load: 42.3 %
Speed: 28.0 km/h
Temperature: 104.0�C
Temperature: 40.0�C
Voltage: 14.097 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 180127 km
Time Indication: 0
Date: 2019.04.21
Time: 17:06:57
Freeze Frame:
RPM: 712 /min
Load: 52.5 %
Speed: 1.0 km/h
Temperature: 43.0�C
Temperature: 34.0�C
Voltage: 14.097 V
000769 - Cylinder 1
P0301 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 180127 km
Time Indication: 0
Date: 2019.04.21
Time: 17:06:57
Freeze Frame:
RPM: 712 /min
Load: 52.5 %
Speed: 1.0 km/h
Temperature: 43.0�C
Temperature: 34.0�C
Voltage: 14.097 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 180127 km
Time Indication: 0
Date: 2019.04.21
Time: 17:06:57
Freeze Frame:
RPM: 712 /min
Load: 52.5 %
Speed: 1.0 km/h
Temperature: 43.0�C
Temperature: 34.0�C
Voltage: 14.097 V
000774 - Cylinder 6
P0306 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 180127 km
Time Indication: 0
Date: 2019.04.21
Time: 17:06:57
Freeze Frame:
RPM: 712 /min
Load: 52.5 %
Speed: 1.0 km/h
Temperature: 43.0�C
Temperature: 34.0�C
Voltage: 14.097 V
008569 - Bank 2; System Too Lean off Idle
P2179 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 180229 km
Time Indication: 0
Date: 2019.04.23
Time: 16:50:42
Freeze Frame:
RPM: 1680 /min
Load: 31.8 %
Speed: 11.0 km/h
Temperature: 100.0�C
Temperature: 66.0�C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
004105 - Mass Air Flow Sensor 1/2
P1009 - 004 - Implausible Signal from Load Calculation - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 180229 km
Time Indication: 0
Date: 2019.04.23
Time: 16:52:15
Freeze Frame:
RPM: 1779 /min
Load: 23.5 %
Speed: 22.0 km/h
Temperature: 66.0�C
Voltage: 14.224 V
000257 - Mass Air Flow Sensor (G70)
P0101 - 004 - Implausible Signal - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 180231 km
Time Indication: 0
Date: 2019.04.23
Time: 16:57:29
Freeze Frame:
RPM: 2095 /min
Load: 100.0 %
Speed: 31.0 km/h
Temperature: 99.0�C
Temperature: 69.0�C
Voltage: 13.970 V
000267 - Mass Air Flow Sensor (G246)
P010B - 004 - Implausible Signal - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 180231 km
Time Indication: 0
Date: 2019.04.23
Time: 16:57:29
Freeze Frame:
RPM: 2095 /min
Load: 100.0 %
Speed: 31.0 km/h
Temperature: 99.0�C
Temperature: 69.0�C
Voltage: 13.970 V
theheaterworks is offline
Just a refresher on the Secrets of the Touareg JAGERVEGAS General Maintenance & Repair 57 02-20-2014 05:31 AM
Parting out dismantled 2006 Touareg , less then 60 miles of use! Gregsparts111 Commercial Posts 20 08-13-2013 01:59 PM
2006 VW Touareg , Less then 60 miles of use Parting out! Gregsparts111 Commercial Posts 73 07-20-2013 10:33 AM
