Has anyone in the history of the touareg ever... - Club Touareg Forums
post #1 of 4 Old 02-04-2014 Thread Starter
I have searched the interweb for the problem of a touareg having the ESP/ABS/Downhill issues on the dash.
What I have found are only ideas of what the solution MIGHT be, along with rants about local VW shops.
If you have found a write up, forum, or just flat out know how to fix this issue you should reply to this thread, and the admin shoud sticky it.
Thanks for your help - my touareg is having this issue.
Blake is offline
post #2 of 4 Old 02-04-2014
I don't quite follow what your issue is.
Would you like to expand upon your problem to give everyone a bit more meat to work with?
Have you scanned the car on VCDS to get any fault codes? Always the first starting point with a Touareg really.
And a thread title should always say what the problem is, not some random statement no one can search for even if you find a fix to whatever your problem is!
"Has anyone in the history of the touareg ever..." farted, had sex in the back seat, snorted coke, laundered money, driven up a steep hill, gone round the bend . . . ? Done some but not all!
post #3 of 4 Old 02-04-2014 Thread Starter
Its the ESP/ABS/Downhill warning dash lights lit up on the dash I am needing help with.
I scanned the car and posted the results some time back, you actally posted on that one as well.
You are cracking me up with farted, had sex LOL. I address the search issue with adding it to the sticky or DIY folders.
I have noticed that there are loads of problems listed, few follow ups on how people/dealers fixed the problems.
I have had the car a my local porsche dealer, working on this some, I am having there canbus scan it Saturday.
I scanned it sometime back:
VCDS Version: Release 11.11.2
Data version: 20120126
Whisenant
Saturday,21,December,2013,12:07:33:17667
Chassis Type: 7L - VW Touareg
VIN: WVGCM77L15D008520 Mileage: 239730km/148961miles
Address 01: Engine Labels: 077-907-560-AXQ.lbl
Part No SW: 4D0 907 560 DB HW: 8E0 907 560
Component: 4.2L V8/5V G 0010
Revision: 00000000 Serial number: VWZ3Z0D5210196
Coding: 0007875
Shop #: WSC 31414 000 00000
VCID: 69D90B7A4362C3B
No fault code found.
Readiness: N/A
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 AQ
Component: AL 750 6A 0551
Coding: 0004200
VCID: 7DF14F2A27EA4FB
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 E
Component: ESP ALLRAD MK25 0202
Coding: 0014338
VCID: 3B758132797E81B
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Part No SW: 3D0 909 135 K HW: 5WK 470 25
Component: Kessy 6400
Coding: 0000232
VCID: 2D51BF6AB70A1FB
Part No: 3D0 909 135 K
Part No: XXXXXXXXXXX
Component: ELV XXXX
No Faults Found
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0020030
Shop #: WSC 24421 551 00000
VCID: 3561970A5F5A57B
1 Fault Found:
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 K
Component: 2703
Coding: 0101534
VCID: 4487FACE0480FE3
4 Faults Found:
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus - Intermittent
000 - -
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory - Intermittent
01520 - Rain and Light Recognition Sensor (G397)
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 C
Component: 05 Airbag 8.4E++H01 0352
Revision: BB36963 Serial number: 00027302
Coding: 0012341
VCID: 23455952E1CED9B
Part No: 7L0 959 339 D
Component: BF-Gewichtsens. 005 0007
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 D
Component: Lenksäulenmodul 3301
Coding: 0000031
VCID: 408FF6DE1098E23
No Faults Found
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 970 L
Component: KOMBIINSTRUMENT RB8 1821
Coding: 0005231
Shop #: WSC 25428 444 57477
2 Faults Found:
00771 - Fuel Level Sensor (G)
00438 - Fuel Supply Sensor 2 (G169)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: F0EFE61EE0B8B23
1 Fault Found:
00463 - Control Module for Digital Sound Package (J525)
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
Shop #: WSC 00000 000 00000
VCID: 4581E7CA0FBAC7B
Address 22: AWD Labels:
VCID: 55A1378AAC1A77B
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000003
VCID: E6C38046D27C6C3
Address 36: Seat Mem. Drvr Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0702
VCID: F7FDDD0285D6E5B
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000003
VCID: E7DD8D42D57675B
No Faults Found
Part No: 7L0 959 933 E
Component: H4 HSG 0201
Coding: 0000085
Shop #: WSC 25428 444 59345
VCID: 3E7388266A6C943
Part No: 7L0 959 701 A
Component: Tuersteuergeraet FS 0201
Part No: 7L0 959 702 A
Component: Tuersteuergeraet BF 0201
Part No: 7L0 959 703
Component: Tuersteuergeraet HL 0201
Part No: 7L0 959 704
6 Faults Found:
00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent
01516 - Terminal 30; Left
00926 - Terminal 30
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
01830 - Bulbs for Fog-Lamps; Rear
009 - Open or Short to Ground - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 7L6 035 456
Component: 08K Audioverst. 0105
Note: Excessive Comm Errors
Address 56: Radio Labels: None
Part No: 7L6 035 180
Component: Radio DE2 0009
Coding: 0001035
VCID: EADBF476C664483
No Faults Found
Address 68: Wiper Electr. Labels: None
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414 000 376832
VCID: 377D9D024556A5B
No Faults Found
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 F
Component: DACHDISPLAY 0530
Revision: 00600530 Serial number: 2009289.02
VCID: 3A7B84367644B83
No Faults Found
End ---------------------------------------------------------------------
Blake is offline
post #4 of 4 Old 02-04-2014 Thread Starter
I did post this is the wrong area, my B.
Blake is offline
