Ac drain plug - Club Touareg Forums
post #1 of 8 Old 10-08-2015 Thread Starter
Ac drain plug
Help I have a 2005 Volkswagen tourag and I got real helpful information on how to clean Ac drain pipe on passenger side but problem is I have a ton of water sloshing around on drivers side and water comes out on foot when I turn the corner. How do I get the water out on that side. Water came out in passenger side but not a ton.. I tried running wire up both directions on drain but not a hole lot of water came out.. HELP!!! I don't want to fry my wiring
Dillon4fam is offline
post #2 of 8 Old 10-08-2015
post #3 of 8 Old 10-08-2015 Thread Starter
thank you so much for such a quick response I'm definitely trying this
post #4 of 8 Old 10-08-2015
You are welcome. You have a cowl drain on each side. Don't forget to check-clean both sides.
post #5 of 8 Old 10-08-2015
nikoloz's Avatar
i dont know if you have found this thread already but here it is https://www.clubtouareg.com/forums/f4...ue-210137.html ice cold water was splashing on my right foot and the problem was this AC drain, so have a look and also remove those drain rubber things under the wheel liner i have already done it 3 years ago
nikoloz is offline
post #6 of 8 Old 10-10-2015
Interesting, I did not know about this. How often should one check/clean/drain these?
Sent from my SM-N910V using Tapatalk
SDonahue1981 is offline
post #7 of 8 Old 10-10-2015
If you park outside under trees, check it at least once a year. It seems to be vegetation/derbies that clogs up the cowl drains.
SDonahue1981 (10-11-2015)
post #8 of 8 Old 11-28-2017
Thanks for sharing; this is very informative and helpful!
yching is offline
