Air suspension conversion to spring suspension - Page 2 - Club Touareg Forums
post #11 of 11 Old 07-08-2015
Olatunde's Avatar
Dears,
Can I use CAT Diesel Engine Oil 15w-40 to service my VW Touareg V10 TDI 2006 model ? See technical sheet below
Performance Requirements
Cat 3406E Endurance Test
Cat C13 ACERT Endurance Test
Cat 3500 Series Test
Cat C13 ACERT Wheel Loader Test Improved Soot-Viscosity & Shear Control High Temperature Shear
Elastomer Compatibility
Piston ring & Cylinder liner wear
Valve train wear, sludge, oil filter plugging Aeration Control
Bearing Corrosion
Cam roller follower pin wear
Copper, lead and tin erosion
Foaming Control
Viscosity Shear loss
Viscosity Increase from soot
Oxidation
Piston deposits and oil control
Test Commercial
Cat DEO
ECF-1
Cat Proprietary Cat Proprietary Cat Proprietary Cat Proprietary
Typical Characteristics*
SAE Viscosity Grade
API Service Classification
Diesel
Gasoline
OEM Performance Level:
Caterpillar Volvo DDC Cummins Mack
Flash Point, C (ASTM D92) Pour Point, C (ASTM D97) Viscosity
cSt @ 40C (ASTM D445)
cSt @ 100C (ASTM D445) Viscosity Index (ASTM D2270) Sulfated Ash, % wt. (ASTM D874) TBN (ASTM D2896)
Zinc, % wt. (ASTM D4951) Gravity @ 16C
API (ASTM D287) Specific
10W-30
CI-4, CH-4, CG-4, CF-4/CF SL
ECF-1 VDS-2
CES 20071/76 EO-M Plus 227
-33
76 11.5 145 1.3 11.3 0.146
31.8 0.867
15W-40
CI-4 PLUS, CI-4, CH-4, CG-4,CF-4/CF SL
ECF-1
VDS-3
93K214
CES 20071/76/78 EO-NPP ’03, EO-M Plus
224
-30
120.5 15.5
135
1.3
11.3
0.146
29.3 0.880
*The values shown are typical values and should not be used as quality control parameters to either accept or reject product. Specifications are subject to change without notice.
Olatunde is offline
