What makes VW 507 oil so necessary? - Club Touareg Forums
 14Likes
post #1 of 168 Old 05-27-2016 Thread Starter
Second Vehicle: 2015 V6 TDI
I can't help but to think, if our vehicles-3.0 TDI motors-are so special, so expensive and so exclusive, why do we need the magical VW 507 spec. oil? What is it in our motors that makes them so seemingly magical that they need this oil we can't just by at Vatozone, Advanced Auto, Walmart, etc. and have to pay about $10 a quart for?
BenTDI is offline
post #2 of 168 Old 05-27-2016
There's a number of factors. One is the DPF, a cheaper oil will produce more soot as it is inevitably burned off in small quantities and lower the life of your filter. Another is the extended drain interval; the oil must be able to run in various temperature and conditions for 10,000 miles without significant loss of lubrication or deposit buildup. Bottom line: German engines are built to very tight specifications, and although you might be paying a bit more for the oil for them, this is definitely not something I would ever go cheap on.
cb62fcni is offline
The Following User Says Thank You to cb62fcni For This Useful Post:
BenTDI (05-27-2016)
post #3 of 168 Old 05-27-2016
Europe has used ever higher specification oils for a long time, several decades - so even brands that define oil "simply" by API viscosity and ACEA grade are expensive for modern engines because they're very high quality and permit exceptionally long OCI, up to 30,000 miles in a few cases, that's right 48,000 km.
VW seem to specify oil differently, or perhaps it's secretly, so the specific VW Approval needs to be adhered to.
Black Grouse is offline
The Following User Says Thank You to Black Grouse For This Useful Post:
BenTDI (05-27-2016)
post #4 of 168 Old 05-27-2016 Thread Starter
Thanks guys. I totally forgot about the soot factor and the diesel part of things.
I have no problem with paying whatever it costs for the oil at all, I just realize that I need to plan ahead and just have some around for when the level drops a bar here or there.
I have been towing the past month and a half and after 4,000 miles since the last oil change, the oil level has been down from 3 bars (12 oz.) to 5 bars (20 oz.) if I had read correctly, each bar is right around 4 oz.
I do like the 10,000 OCI.
BenTDI is offline
post #5 of 168 Old 05-27-2016
fincher's Avatar
Of course, Porsche switched to 5k oil changes here for the diesel Cayenne because of our lower fuel quality. This happened early on when the 2013 model came here.
I stick with 10k and have no issues. Plenty of members here change more frequently.
2012 Touareg TDI Exec (Cool Silver/Anthracite) | Aluminum Pedal Covers | Warning Triangle | Euro Mats | Auto Hold Switch
fincher is offline
post #6 of 168 Old 05-27-2016
compu_85's Avatar
507 oil is designed to protect the DPF and cat, and to improve fuel economy. Mercedes has a similar standard, I think with less emphasis on fuel economy so 5w40 oils are allowed.
-J
04 Touareg V10 TDI - 150,000 miles
12 Passat TDI - 92,000 miles
99.5 Jetta TDI - 305,000 miles
91 Mercedes 350 SDL. Yes, it bent the rods.
91, 92 Jetta ECOdiesels. Gone and missed.
compu_85 is offline
post #7 of 168 Old 05-27-2016
VW-a-holic
Oregon TDI's Avatar
My dealer sells Castrol LL03 for under $7 a bottle (liter). Just not worth my time to look for it elsewhere.
Oregon TDI is offline
The Following User Says Thank You to Oregon TDI For This Useful Post:
nickm (05-27-2016)
post #8 of 168 Old 05-27-2016
Philth's Avatar
Can buy Mobil 1 ESP via Amazon for just over $9 a liter delivered. I'm done with teenagers doing maintenance on my cars.
Philth is offline
post #9 of 168 Old 05-27-2016
-J
API 5W-30 / ACEA-C3 is used as generic specification on non-VWs to protect the cat, DPF and improve economy so 507 will be similar - BUT - if it doesn't list 507 among it's Approvals, don't use it.
post #10 of 168 Old 05-27-2016
nickm's Avatar
The big deal about 505 and 507 is specific protection for cam lobe wear. 507 is for dpf and 505 is non dpf. The way the tdi engine is designed, it requires a specific oil to prevent premature cam lobe wear.
Any modern diesel oil can deal with dpfs, but only 507 can deal with cam lobe wear prevention.
--PREVIOUS TOUAREGS:
nickm is offline
The Following User Says Thank You to nickm For This Useful Post:
Oregon TDI (05-27-2016)
