V8 automatic hard down and up shifts - Page 2 - Club Touareg Forums
post #11 of 22 Old 02-22-2015 Thread Starter
Quick up date to all whothis helped on this. Did do a tranny filter change and oil of course, absolutely required it was bad. It has helped 100%, however still got a few hard shifts, but only when the ESP off indicator is on. Have some major connection problems on this car. Nonetheless, the transmission is now operating realtively smoothly for a 10 year old car. But when it gets hot the transmission can get rough again. Really do suspect the valve. Anyone figured away to modify to force to stay open? Buying a new one here is another major problem.
rod1950 is offline
post #12 of 22 Old 02-22-2015
No.
The valve chest is a very complex item.
You need a new valve chest.
post #13 of 22 Old 02-22-2015
nikoloz's Avatar
i think rod1950 was talking about temperature valve. glad for you mate, hope tranny will stay smooth
nikoloz is offline
post #14 of 22 Old 02-22-2015
Ah, okay!
post #15 of 22 Old 02-22-2015 Thread Starter
Yep, it's that Bloody temp switch in the feed to the Tranny cooler under the rad. We have constant 25-30c here so need to warm it up before cooling, it needs it straight away. Anyway would like to fix that thing open as it fails closed. Any suggestions?
rod1950 is offline
post #16 of 22 Old 02-22-2015
nikoloz's Avatar
Are you going to do it yourself? I heard some guys in Russia have connected lines directly to radiator, But i don't know what diameter pipes and fittings you need, Mind you this part o ly costs 100$ new from the dealer
nikoloz is offline
post #17 of 22 Old 02-26-2015 Thread Starter
Nikoloz, yes $100 in US, $200 minimum in Cameroon, if you can get one. I will revert on how I by passed it once done.
Cheers, Rod.
rod1950 is offline
post #18 of 22 Old 02-26-2015
nikoloz's Avatar
thank you mate, im also working on that myself, as i think thats the best and easiest solution, and you will never have to worry about it in the future i hope i will bind the bloody time for that, i have long to do list to do
nikoloz is offline
post #19 of 22 Old 5 Days Ago
Touareg: 2007 V8
Hey guys
I'm having sort of the same issue with my TREG 06 4.2L V8.
Here's what's going on, when I step on accelerator harsh to quickly get around someone it downshifting smooth but then once I don't need acceleration no more it upshifts really harsh from 4-5th with a feeling like I just got rear ended!
I've tried to get around using TIPTRONIC but still same issue.
However it only does it once you step on it to accelerate fast , once at normal driving tranny works and shifts smooth.
Just wanted to see where should I start ? Replacing a fluid and filter only ? Or do a valve aka chest body as well???
Car has 75k miles , no engine or fault codes
IgorB is offline
post #20 of 22 Old 5 Days Ago
Known fault.
You need a rebuilt or a new valve chest fitted to the gearbox.
Plenty of threads on here about it.
color="black"> word word word
