Turbo underboost!! - Club Touareg Forums
post #1 of 6 Old 01-09-2017 Thread Starter
Turbo underboost!!
Hello
I am new to this site and I am unsure if this is the right place to ask, but here is my problem. I own a 2007 Touareg 2.5 R5 Altitude and have a Turbo underboost code reading. I have replaced the TURBO - EGR VALVE - THROTTLE BODY - N75 VALVE - EGR COOLER - MAF SENSOR - MAP SENSOR and have had a TERRACLEAN internal engine clean. Is there anybody out there that may have some idea what may be causing the turbo to underboost? Please let me know as i've ran out of idea's. Thanks in advance
nally is offline
post #2 of 6 Old 01-09-2017
Second Vehicle: 2005 R5 TDI
Originally Posted by nally View Post
Hello
When you replaced the turbo did it come with a new diaphragm controller?
Regards
Drag
dragline1570 is offline
post #3 of 6 Old 01-09-2017
Second Vehicle: 2009 V6 TDI
Have you checked the intercooler, pipes and clamps?
Marbles is online now
post #4 of 6 Old 01-09-2017
Regards
Drag
Ditto, not sure the setup of the R5 turbo but if it has a vane position sensor like the CKRA 2.0LCr the vane lever needs to be surgically adjusted to achieve proper turbo vane position, it may cause an underboost or overboost if positioned wrong.
Dpkhym is offline
post #5 of 6 Old 01-09-2017
Blownvette's Avatar
Second Vehicle: 2008 V10 TDI
Try and replace the n18 valve, it was a problem for me on my 04 V10
3 V10TDI's: 2004, 2008 Touaregs and 2004 V10TDI in 1990 Corvette
Blownvette is offline
post #6 of 6 Old 01-09-2017
4ePikanini's Avatar
Touareg: 2005 R5 TDI
I presume you checked for vacuum leaks between n75 (top left in picture) and vgt actuator? Probably a sticky vane mechanism.
Does yours behave like this?
2001 Gen3 Di-D LWB - SOLD
4ePikanini is offline
