Possible HP Fuel Pump issue with CASA/CATA engines - Club Touareg Forums
 25Likes
post #1 of 112 Old 04-13-2017 Thread Starter
Moderator
hedditch's Avatar
Whilst visiting my local Third Party VW Specialist yesterday, They informed that they have had two CASA V6 Tdi engines with catastrophic High Pressure Common Rail Pump failures in the past two weeks.
Both engines had done over 200,000 km and in both cases the HPFP had disintegrated resulting in metal fragments and filings being forced through the injectors, This resulted in total loss of not only the pump ( about AU$ 1,200 ) but also the injectors ( about AU$ 600 each ) resulting in a repair bill of over AU$5,000 plus labour.
The vehicles involved were apparently stock standard and had not be subjected to any apparent abuse. They don't have enough information as to the root cause but suggested that it may be related to fuel quality. They also stated that I may be interested in looking at Diesel Fuel treatments as a form of insurance. Understanding that they DON'T sell such products, and were only thinking out loud as to what may be useful.
At this stage the failure of two engines may be simply bad luck, which I sincerley hope is the case. I think it is something I will be following closely to see what more information I can find.
Kind Regards
Stuart....
hedditch is offline
post #2 of 112 Old 04-13-2017 Thread Starter
Moderator
hedditch's Avatar
References from Other Sources & Forums.....
Catastrophic high pressure fuel pump failure - TDIClub Forums
3.0 HPFP Failure, 2009 Q7 220k - TDIClub Forums
https://www-odi.nhtsa.dot.gov/acms/c...1003-61863.pdf
HPFP Failure
hedditch is offline
post #3 of 112 Old 04-14-2017
Australian diesel is only just within the fuel spec for the pumps - just. No tolerance. Yes a fuel additive to increase lubricity is advised if you intend to keep your treg. There is a lot of detail on the web on this - somewhere there was a comparison of the benefits of different additives.
A start is here: 2 Stroke Oil In Diesel ? - myTreg forums - Page 3
MY13 V6 TDI 4Motion
Previous: BMW X3 3.0d, Subaru outback and the odd Alpha.
Toiler is online now
post #4 of 112 Old 04-14-2017
Second Vehicle: 2006 V6
Yes Stu HPFP failure is a real costly exercise.
I believe adding either synthetic 2 stroke oil or a diesel fuel lubricity additive like Flashlube or the like to your fuel will help.
Are there enough failures out there to justify the pump as a maintenance item at say 175 to 200 kms ?
Costly exercise but way cheaper if you were to have a failure.
As a note relating to the video Touareg TDI's pumps are not driven by the timing belt and are not timed.
regards
Drag
dragline1570 is online now
post #5 of 112 Old 04-14-2017 Thread Starter
Moderator
hedditch's Avatar
I will be ordering a replacement HPFP this coming week, as I currently have 220,000 km on the clock, and replacing a pump is cheaper than replacing a pump + a full set of injectors. It might look like "overkill" however I am a firm believer in "Preventative Maintenance" rather than Restorative Repairs.
Stu.....
hedditch is offline
post #6 of 112 Old 04-16-2017 Thread Starter
Moderator
hedditch's Avatar
This YouTube Video gives a good insight to the cause of HPFP failure in TDI engines. Even though it relates to a Jetta 4 cylinder engine the process is exactly the same.
Stuart....
hedditch is offline
post #7 of 112 Old 04-16-2017
is there a extended HPFP warrantee on T3's in the US?
VWcheats is offline
post #8 of 112 Old 04-16-2017
Mythdoc's Avatar
Touareg: 2011 V6 TDI
There will be when the settlement is approved.
2011 TDI Exec Silver/Saddle Brown -- 74K Miles
2015 Q5 TDI Cuvée Silver/Chestnut Brown -- 10K Miles
2012 Chevy Silverado 2500 V8 Crew Cab
Mythdoc is offline
The Following User Says Thank You to Mythdoc For This Useful Post:
BeemerMikeTX (04-16-2017)
post #9 of 112 Old 04-17-2017
alfissimo's Avatar
Kind Regards
Stuart....
Has anyone come up with a upgraded version? I checked LOBA but they have nothing. I have been thinking about replacing mine as well just as preventative maint. I always use a lube (Titan Diesel additive) or about a pint of B100 at fuel ups.
Jason
- 10' TDI
alfissimo is offline
post #10 of 112 Old 04-17-2017 Thread Starter
Moderator
hedditch's Avatar
I will be ordering a replacement pump today, because I now have 230,000 km (130,000 mile) on the clock, and I have not been using any fuel additives. My thinking is a pump is cheap compared with a failure.
Stuart....
hedditch is offline
The Following User Says Thank You to hedditch For This Useful Post:
Spiegelglatt (04-17-2017)
