Glow plug stuck - workshop suggested engine drop! - Club Touareg Forums
post #1 of 24 Old 01-09-2017 Thread Starter
Alright, folks... Glow plug exchange complete at an engine workshop, all brand new now except number #6, which is stuck. And the most difficult one to get access into.
Guys refused to turn because they wanted a confirmation from me due to the plug possibly braking in the process.
First estimate was that they can probably remove it with drilling techniques, which would result in a moderate repair cost. This is the option that realizes in most cases.
The second, and worst, estimate is that, should the plug get broken or should the tip fall into the cylinder, they have to drop down the engine in order to remove the cylinder head, in which case they definitely can remove the plug, but this option is very costly.
What surprises me most is that the engine needs to be dropped even in case of the V6. This is one main reason why I stayed away from the V10 when purchasing my car to avoid costly engine removals...
I decided to hold back for now and think for possible other repair options, if any exist. I have read about various magnetic fluids/oils that you should spray on the neck of the plug while juggling it back and forth using small steps to get the soot off which keeps the plug stuck from the inside, but this seems like a lengthy and cumbersome operation to take on a vehicle that is in constant daily use.
Any suggestions from fellow T-Reggers? I have a very strong love-hate -relationship with my vehicle, and now the scale is leaning towards the hate side again...
Naturist's Touareg
T2 2008 V6 TDI 176 kW, Retrofitted OEM Spare Wheel Carrier on Tailgate, Steel Spring Suspension, Rear Diff Lock, Park Distance Control F&R, RNS 510 Navi, Power Latch for Tailgate, Adaptive Bi-Xenon headlights, Retrofitted reversing camera /w Kufatec interface to RNS510, Webasto+REMUC remote control
Naturist is offline
post #2 of 24 Old 01-10-2017
Get the motor f****** blasting hot and soak with penetrate then let cool overnight do that about 5 times then remove the glow plug with the motor warm.
Tell me you tested your rear battery before replacing the glow plugs for a glow plug fault.
Dpkhym is offline
post #3 of 24 Old 01-10-2017
Scubacruiser's Avatar
No rear battery on a V6 TDI.
"Sophie" - 2010 Touareg TDI Highline, Campanella white on Anthracite
Scubacruiser is offline
post #4 of 24 Old 01-10-2017 Thread Starter
I have read the fault codes using VCDS, and indeed there was a glow plug #6 open circuit as the only fault code. The battery is fine (no rear battery because of no parking heater from factory - just the auxiliary one).
I will need to think whether I will try some DIY stuff with this or not. I have minimal experience on engine repairs, but on the other hand, it's already close to "being broken" and the repair costs will anyway be huge, so I got nothing to lose... Just will need to make sure that the cylinder head stays intact!
Naturist's Touareg
Naturist is offline
post #5 of 24 Old 01-10-2017 Thread Starter
Thanks for the tip!
For penetrating oil spray or something similar, do you have some particular product in mind?
Naturist's Touareg
Naturist is offline
post #6 of 24 Old 01-10-2017
I don't know what is available in Europe. Over here, my favorite product is Kano Aerokroil.
buckwheat is offline
post #7 of 24 Old 01-10-2017
Wd40,JB80, anything designed as a penetrating oil
Dpkhym is offline
post #8 of 24 Old 01-10-2017
I very respectfully disagree. I'm a fan of Kano products, but others, like PB Blaster have an excellent reputation:
WD-40 Oil Alternatives - The Case Against WD-40
and from some undocumented comparison, you can see quite a difference in breakout force for various products.
For all of you that are mechanically inclined..... Penetrating Oils Compared A study done by Machinist's Workshop magazine in their April 2007 issue looked at different penetrating oils to see which one did the best job of removing a rusted bolt by measuring the pounds of torque required to loosen the bolt once treated. If the study was scientifically accurate, it turns out a home brew works best! Here's the summary of the test results:
Penetrating oil .......... Average load
None ..................... 516 pounds
WD-40 .................... 238 pounds
PB Blaster ............... 214 pounds
Liquid Wrench ............ 127 pounds
Kano Kroil ............... 106 pounds
ATF-Acetone mix.............53 pounds
The Automatic Transmission fluid (ATF)-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. A local machinist group mixed up a batch and all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.
I've spent way to many hours on 2 hour jobs that take 6 hours due to rusted or broken fasteners to use something like WD-40.
post #9 of 24 Old 01-10-2017
PB Blaster sprayed on a rusted exhaust part for 3 days straight can work miracles.
Also, fyi. PB Blaster sprayed in an attached garage for 3 days can lead spouse in attached house to file for divorce. It has a wee bit of an odor.
post #10 of 24 Old 01-10-2017
Rudster's Avatar
Aero kroil's a real bugger if you get in in your eye too.
But yeah, definitely have a go at the glowplug with penetrating oil. Should do the trick.
Rudster is offline
