2012 TDI with engine light on at 339 miles - Page 21 - Club Touareg Forums
post #201 of 351 Old 08-10-2012 Thread Starter
Question Newest Problem is an adblue pump failure!!!!! HELP
Yesterday I returned my 2012 Touareg TDI to the dealer for the engine light on. I was told that they code was showing an adblue pump failure. They told me that they called the VW tech line and they were told to refill the adblue and then reset the level manually. They did that and reset the check engine light. So far it seems to be ok but I never had an adblue level low indicator come on. I wonder if they know what they are doing or if they are just feeding my a line of BS. This is the 2 time I have had a problem with the CEL coming on. I read on this site that the CEL will not come on for a low adblue level. Is this correct? Any info you can give me would be helpful.
Thanks in advance,
Michael
Mjc4370 is offline
post #202 of 351 Old 08-10-2012
Second Vehicle: 2012 V6 TDI
Thanks in advance,
Michael
How many miles have you put on your TDI since you last had the light come on? How is your style of driving? Aggressive?
The next question is have you read your Owners Manual, and what does it say?
Niner is offline
post #203 of 351 Old 09-12-2012
Interesting thread. My Check Engine Light came on at 6,400 miles. Spoke with dealer, did not feel it was urgent, but they were happy to check it out.
Dropped it off, and apparently remote diagnostics from Germany, and a new software flash for the reductant (add blue) pump. Picked it up, and so far no issues. My error code was P2086.
When asked about the software date, they indicated this version had not yet been formally released. Leads me to believe it is an advanced Beta version that they have been tweaking. Pretty standard stuff.
For those who think other brands are any better, reality check. I have owned a 500 Mercedes, my wife drives a Lexus, and my previous Touareg, and so far my new TDI have fewer mechanical issues, and for me much better design.
The only problem I have with the 2012 Touareg are the redesigned back seats that only drop 2/3 of the way down. I am an underwater photographer with lots of camera and dive gear, so this is an issue. Took a long look and many test drives in a comparable Mercedes, which cost the same, and bottom line was I liked the Touareg better.
MB has a slightly more comfortable interior, and rear motor is mounted on top of hatch, not below. It also has annoying paddle shifting. Touareg drives better, engine reviews are better, and the VW dealer is far superior to the MB and Lexus dealers.
For me, VW has done a great job on the Touareg. Taking it in to have the ad blue pump computer reflashed is no big deal.
Dan_Clements is offline
post #204 of 351 Old 09-14-2012
Glad to hear that they flashed a fix for this. My engine light came on around 600 miles and it was the adblue pump failure. Adblue pump is working and I was told VW is waiting for a software fix. Also the Touareg Excecutive care has told me the same thing, that VW is working on a software fix. So hearing you had an update put in make me feel they are about there for releasing it.
By the way, I love my Touareg.
jchristilles is offline
post #205 of 351 Old 09-14-2012
ConservativeConsumer's Avatar
The updated AdBlue firmware (FW) has been released in November 2011. My AdBlue issues were resolved by upgrading FW in November and replacement of the AdBlue pump a couple of months later. Can you check with your dealer if they are talking about absolutely new level of firmware or they are simply a bit behind times and talking still about the 11-2011 vintage FW? Just curious. Thanks in advance!
post #206 of 351 Old 09-16-2012
My dealer told me this is new firmware they are working on. There was another one last year but did not work.
post #207 of 351 Old 09-17-2012
I think someone got the CEL reset and sent back out the door with fresh load of BS too?
Does anyone know what the current release date is? Or in fact is this a beta version being used?
CBRDude is offline
post #208 of 351 Old 09-17-2012
There is another thread on the AdBlue subject in which a guess was expressed that there are different models of AdBlue pumps around requiring different firmware. I personally think that’s the case and this adds a confusion in our forum discussions. In last November, I was told that my AdBlue pump was of a newer model than the FW downloaded at the factory – thus it operated wrong for 4k miles and failed prematurely at 5.4K miles. They’ve loaded new FW in November but this was too late – pump went bad in January. I wonder if there is a 3-rd generation solution – newer pump and newer FW.
post #209 of 351 Old 09-17-2012
ConservativeConsumer, what is your build date? I've not had any AdBlue issues, but plenty of other issues. In the shop currently!
CBRDude is offline
post #210 of 351 Old 09-17-2012
I have no idea what the build date of my 2012 Touareg is. I’ve signed papers in late August of last year. Normally, Touareg US order-build-delivery time is about 2-3 months, so my guess is that mine is of June’s vintage.
As far as I can say from occasionally following your story through in different threads, it is unlikely that your situation connected to a particular build date of the vehicle. In my subjective opinion, your dealer Service Department has created more problems than they’ve solved, but who am I to judge?
Hope your lemon efforts, however unpleasant, are coming to a successful conclusion.
Engine Warning Light Question - 2011 Touareg TDI colegar Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 51 03-26-2015 10:46 PM
Engine tuning (Re-map) 2012 Touareg V6 TDI ryanfrancis7 Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 19 05-18-2012 10:41 PM
2012 TDI studder/hestitation upon initial or light accleration ATS579 Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 7 04-16-2012 01:17 PM
fan running when engine off and check engine light on prosh General Maintenance & Repair 9 01-30-2010 03:53 PM
V-10 TDI Engine Light hprotter General Maintenance & Repair 3 09-16-2008 10:35 PM
