163427km on the 2005 V8 engine. I literally came back from a 8 km long, gentle drive, and as I pulled into my driveway(thankfully!!), I smelled a burned rubber/oil almost borderline electrical type of smell coming out through the dash vents. I stepped out, and could detect the same odour emanating from the front of the vehicle as well. I allowed the engine to idle as I opened up the hood. What I observed immediately startled me, smoke was beginning(in very small quantities) to come out both from both sides of the engine, originating from somewhere below it seems. I then immediately proceeded to shut off the engine. Now here comes the part that scared me the most, to the point that I contemplated taking out the fire extinguisher and garden hose. The spewing of smoke increased about 3 min after I shut off the engine, and continued to do so up to a good 5 after engine shut down, and then stabilized and would slowly begin to ease up until it eventually stopped 10 min later! I wish I had taken a vid of it. We are not talking incredible amounts of smoke, that would be seen by passers by 100 meters away, but it was borderline enough for the 6th sense to start preparing for evasive manoeuvres. There was never any indication of this in the past, as I wrote, it literally began as I pulled into my driveway with a slight odour through the fresh air vents, after a gently drive to go run some errands.....and then all hell ALMOST broke loose.
Any ideas as I begin to contemplate my next course of action?
I did of course do a quick visual inspection from the top to see any kind of oil seepage or leakage, and none that I could find. Also looked at the driveway for spotting, nothing there as well.
