Oh no! I've got the clunks! - Club Touareg Forums
post #1 of 31 Old 09-16-2015 Thread Starter
I think I know the answer to this one already but I want to check before I go looking for parts. Got a call from my wife, pulled over on the freeway, said "there was a loud noise, I thought I had a flat tire but I don't!" So I run over and sure enough no flat tire but if I get above 30-35mph it starts clunking like the car is trying to rip itself apart and I can feel a lot of vibration through the armrest. I have to slow to 10-15mph for the noise to stop and then once again it's safe up to about 30-35mph.
I'm relatively certain this is the center support bearing failure on the propshaft and that my best plan of action is to get a refurbished shaft from Colorado Driveshaft. This is a 2004 V8 with about 155k on the clock, by the way. I got the car at around 100k so I don't know if this has been replaced in the past.
Is there any other likely problem or solution here?
zerodb is offline
post #2 of 31 Old 09-16-2015
TJay's Avatar
Touareg: 2009 V8
Second Vehicle: 2007 V8
Do some searching here - tons of info on this. You can probably just replace the support bearing and not the entire drive shaft for a lot less money. Good luck & let us know how you make out!
TJay is offline
post #3 of 31 Old 09-16-2015 Thread Starter
It looks like the refurb shaft is only like $375 by the time I return the core, and the Vertex split bearing support is $400 by itself... I'm sure it's a little quicker to install but it doesn't seem like it would save me much!
zerodb is offline
post #4 of 31 Old 09-16-2015
Odessa's Avatar
get under the car and inspect the support bearing see if there is excessive play
Odessa is offline
post #5 of 31 Old 09-16-2015 Thread Starter
The shaft seems to move with almost no resistance with one-handed non-herculean strength.
I haven't been actively involved in automotive engineering for a few years now, but I'm pretty sure it's not supposed to.
zerodb is offline
post #6 of 31 Old 09-16-2015
Odessa's Avatar
sounds like you found the problem. If you can view the rubber support while moving (with a torch) then you should see the movement in the rubber which is the problem.
New bearing support needed i would say
Odessa is offline
post #7 of 31 Old 09-16-2015
Touareg: 2008 V6
Ya, definitely sounds like support. I went with the Vertex Automotive solution found on Amazon. It was very easy. The only thing I'm glad I had was an extra pair of hands and an angle grinder to cut the original bearing support off. Once that was off, we just took the angle grinder to the bearing and gently angled it properly to spin the bearing but also remove the rubber that is adhered to the bearing. Also a razer blade will work nicely, but will take a lot longer.
Everything is running smooth in my Treg! Hope you can find a quick and permanent fix to your problem.
2008 Touareg, 2014 Tiguan, 1980 CB750 (project bike)
JaysonRL is offline
post #8 of 31 Old 09-26-2015
G6mdxvct's Avatar
Go with the vertex as there is nothing wrong with the shaft. Hardest part is getting the old rubber off the bearing. I used a carpenters blade and cleaned easily to bear metal. Took me less than 15 minutes to install the vertex once prepped. Very well built hefty product and no worries about getting an unbalanced shaft which can happen if you buy a shaft rebuild.
G6mdxvct is offline
post #9 of 31 Old 10-04-2015
Runz12s's Avatar
Touareg: 2012 V6 FSI
Same exact thing happened to me last night while in route to get new wheels,, thought I had a flat at first. Anyway found this company http://www.coloradodriveshaft.com/vo...en_touareg.htm Wonder if anybody tried them
Runz12s is offline
post #10 of 31 Old 10-04-2015
You obviously haven't bothered to use the Search facility on here . . .
color="black"> word word word
